4.0 SOHC Starting Problem
Old Feb 17, 2008 | 09:31 AM
flapjack's Avatar
flapjack
I have a 2001 Ranger XLT 2WD, Auto Trans, 55,000mi. Recently I have experienced a drop in rpm when putting it in park. It drops to about 500rpm, then picks back up. Yesterday I drove to work, out to lunch with no problems. I went to go home and it wouldn't run. It would crank fine, but not start until I gave it a little throttle. It would then run, but really rough. If I tried to let it idle, it would die. When it did run, there was no CEL. I left it at work overnight. I went to work this morning and it started up fine with no problem. I started it several times during the day and didn't have any problem driving it home.
Any help would be deeply appreciated.
(I had origianlly posted this in the ranger forum)
Old Feb 17, 2008 | 10:09 AM
Lead Head's Avatar
Lead Head
Your idle air valve is sticking. Either need to replace it or clean, I believe its on the center top of the intake plenum underneith the "4.0 SOHC" cover
CopenGrizz01
21
Oct 27, 2018 08:53 AM
JMaurer1
1997 - 2003 F150
Jun 10, 2016 12:37 PM
Alex Burdett
Mar 12, 2015 07:55 PM
magneto259
1983 - 2012 Ranger & B-Series
15
Jan 14, 2012 01:56 PM
p3i
Mar 26, 2001 06:45 PM
