difference between 73-77 and 78-79 steering columns
Old Feb 16, 2008 | 08:29 PM
droppedf100's Avatar
droppedf100
What are the difference between the 73-77 and 78-79 steering columns?
Old Feb 16, 2008 | 10:03 PM
Mil1ion's Avatar
Mil1ion
73-77 The NSS is lcoated on the column
78/79 the NSS is on the transmission
This makes the wiring and column connectors different.
also the 77-79 mount to the firewall different
The 78/79's use a plastic shroud to mate to the dash board.
Old Feb 16, 2008 | 10:58 PM
droppedf100
Can you tell what year this column is.
http://i32.photobucket.com/albums/d6...100/column.jpg
Old Feb 17, 2008 | 12:00 AM
1969F2504X4's Avatar
1969F2504X4
That would be a 78-79
Old Feb 17, 2008 | 12:41 PM
droppedf100
Thanks thats what in looking for.
Old Feb 17, 2008 | 03:46 PM
RCrawler's Avatar
RCrawler
Do the changes in the firewall attaching methods make them non interchangeble?
Jason
Old Feb 17, 2008 | 03:50 PM
Mil1ion's Avatar
Mil1ion
With the right tools you can modify the firewall to make them fit.
Old Feb 17, 2008 | 07:19 PM
RCrawler's Avatar
RCrawler
Is the lower column/ firewall support spot welded to both style columns?
Jason
Old Feb 18, 2008 | 09:16 PM
whd507's Avatar
whd507
no, they swap with relative ease. the NSS as stated previous, is the main difference.
I'm pretty sure that you can swap the collar/base from the 77-79 onto the 73-76 shaft, but dont quote me. I have seen it done.
power steering and non-power steering are different lengths, 4x4 also had splined end, but so do tilt wheels. a splined to ragjoint end piece is needed on 2wd that previously had non-tilt.
Old Feb 18, 2008 | 11:16 PM
Mil1ion's Avatar
Mil1ion
here is the 78/79 column showing its firewall seal
Old Feb 19, 2008 | 12:38 AM
RCrawler's Avatar
RCrawler
Ok, I see now. I parted out a 79 column a while back that didn't have anything for the lower support attached to it. I wasn't sure if it had been removed.
Thank you for the replies.
Jason
Old Feb 19, 2008 | 06:51 AM
whd507's Avatar
whd507
all the holes in the firewall are exactly the same. the gasket is different, but the same. different retainer bolts I think
