Hey guys. I know I should've stuck with my old thread but its buried away now and figured everyones lost interest. Anywho as everyone probably knows my C6 wont shift on its own. New lines, mod and still no shift. Couldnt a easy fix to this to be to just install a manual shifting shift kit in her? That would be really sweet and then I could install a floor shifter. Would that not work?
Note: Topics like this were always best asked in the drive train forum where the transmission specialist's hang out. plus there will be some threads on the same topic in there.
Just trying to be helpful
I have a trouble-shooting guide for the trans if you want me to scan and post it?
i just read that thread, I agree with MHG. Modulators *should* just drop right in. Did you see a small rod when you did the install?? Worst case you have to drop your valve body and get it repaired. Will it shift into 2 if you force the shift?
Million can you scan that for me please, please. I aligned the pin up into the hole in the mod but it was a complete PITA to instal. I mean it took everything I had to get the bogger in, it was like there was a big spring inside the tranny pushing back at me as I was pushing in but when I put my old one back it it was fairly easy to install. It will shift into second if I force it if you mean running the hell out of it to get it to shift. If I remember right it'll even go into drive running the **** outta it.
