351M crank pulley
Old Nov 30, 2002 | 10:28 AM
JJDDOOGG's Avatar
JJDDOOGG
351M crank pulley
How in the world do you get a crank pulley off?????
Ive been beating on it for on hour and it will not come loose.
please help
Old Nov 30, 2002 | 10:42 AM
rjcline's Avatar
rjcline
351M crank pulley
It takes a puller... Auto Zone rents one for free..
Old Nov 30, 2002 | 10:55 AM
JJDDOOGG's Avatar
JJDDOOGG
351M crank pulley
Im talking about the pulley not the harmonic balancer. The balancer takes a puller. Im trying to get the center bolt loose on the belt pulley that bolts into the crank.
Thanks
Old Nov 30, 2002 | 11:04 AM
rjcline's Avatar
rjcline
351M crank pulley
opps sorry, your right..ok how about a 4 foot extension? I have had 3 of these apart this summer and I havent had any trouble with that paticular bolt other than lots of grunt.
believe it or not turpentine is one of the best bolt "looseners" i have ever used...i soak a rag and leave it wrapped around (over night if possible) it always works good for me...
Old Nov 30, 2002 | 08:01 PM
shazam's Avatar
shazam
351M crank pulley
[updated:LAST EDITED ON 30-Nov-02 AT 09:03 PM (EST)]>Im talking about the pulley not the harmonic balancer. The
>Thanks
OK the center bolt holds the harmonic balancer on , while there's "4" 9/16 head bolts that hold the belt pulleys on .
But I use a Big Impact wrench to get the center bolts out. Or you can use a 2 foot piece of pipe over your ratchet....
Old Dec 3, 2002 | 11:30 AM
D9351's Avatar
D9351
351M crank pulley
A bit off the subject, but a trick I found to get the crank bolt loose without the engine spinning is to remove the pulley (that is stuck in your case) and bolt a double box end wrench to the harmonic balancer, and the other end of the wrench to some available bolt like a water pump bolt. Works great for those without a monster air wrench.
Old Dec 3, 2002 | 06:18 PM
JJDDOOGG's Avatar
JJDDOOGG
351M crank pulley
I finally got it off!!! The damper is actually warped. That might be why I had to replace the mains. I was in the scrape yard looking for a damper and found a 400M from a 79 truck and bought it for $150. It actually runs. Thinking about rebuilding it and leaving the 351M in the truck alone. Thanks for the help.
Old Dec 3, 2002 | 06:33 PM
Bill_Beyer's Avatar
Bill_Beyer
351M crank pulley
hollenjoe
Jan 17, 2014 11:06 AM
mudboggin3
Nov 8, 2013 10:47 PM
78sharpshooter
Jun 21, 2007 12:29 AM
HT32BSX115
21
Jun 8, 2005 04:43 PM
