Fuel pressure starting problem
Old Feb 16, 2008 | 10:04 AM
RLP1's Avatar
RLP1
I have a 92 F-250 351w, dual tanks. The motor has been rebuilt and runs very well once I get it running.
My problem is the cold start. After 6 or 8 attempts the motor will turn over and after 15 seconds or so of sputtering all is well. I have checked the fuel pressure at the rail and seem to have found the problem, but the cause is elluding me.
Engine off pressure is only 10 to 12 psi (fuel pump grounded, constant on) and it will not build up any more but does not leak off for at least 15 mins. Once the engine is running, I have 45 psi and when the engine is warm the pressure stays an even 42 psi. (It does not leak off here after shutdown either). Restarting within 1/2 hour is fine.
The filter is new, but I have removed and checked it anyway, no clogs or flow problems. I am running on the rear tank only, since the front tank seems to have a dead pump. (0 psi, and when running switching the tanks will kill the engine)
Any ideas where my problem is?
Thanks in advance for your help.
Old Feb 16, 2008 | 10:23 PM
LxMan1's Avatar
LxMan1
Does a 92 have the frame mounted pump or just 1 high pressure pump in each tank? Sounds like one of the check valves is failing alowing all of the fuel to drain back to tank over time.
Old Feb 17, 2008 | 09:50 AM
RLP1's Avatar
RLP1
It does have the single HP pump in each tank. The check valves crossed my mind, but would they only leak off when the truck had set for a time?
Old Feb 17, 2008 | 05:57 PM
LxMan1's Avatar
LxMan1
Unless you have an injector that is seeping fuel into a cylinder when sitting. It has to be going somewhere.
Old Feb 17, 2008 | 06:14 PM
subford's Avatar
subford
Sounds like low voltage or bad ground.
If it holds fuel pressure after you remove the ground or shut off the engine than the check valves and the shuttle valves in the fuel delivery module are OK.
Try replacing the fuel pump relay and check the voltage at the fuel pump plug.
Also check the fuel pump ground on the radiator support.
LxMan1 did you find out why my posts are being delayed?
Old Feb 17, 2008 | 10:36 PM
LxMan1's Avatar
LxMan1
Working on that . Awaiting a reply.
