stumbles at 160 degrees
the truck runs like a champ hot, and it runs like a champ cold. but it does not like to run luke warm. when sitting in the driveway waiting for it to warm up everything is going fine up until juuuust before the thermostat opens, then she puts up a huge fight and stubles. doesnt load up or anything, just runs real rough and puts up a fight. then when the coolant starts flowing it runs like a raped date. i love my truck and i've spent alot of time and money working on it, everything is real tight and dialed in. the one and only thing thats lingering in my mind is it could be the water pump. maybe the bearings or whatnot are going out and it doesnt like the pressure that the cooling system builds up? around 13 psi i believe....
thanks guys
also can someone please tell me what the fuel pressure is from my stock fuel pump? not that i think this is related i just am wondering
This is assuming you are using a choke thermostat and not a manual choke.
Depending on where you live and the weather, it could be icing up the throttle plates (my V8 Courier did it every year). This is easy to check, start the vehicle with no air cleaner and watch down the throat. If it is icing up, you will see the plates turn white, once the engine is warm it will go away. Wouldn't happen to be running a Holley would you? Icing is usually at its worst just above freezing in damp conditions.
Yeah, I know...no carb stuff...but where else can it be? Timing...no, fuel pressure...no, head gasket...no...if it ran good before and you are having issues now it is something you have done.
Good luck!
Kenny
Also monitor the alternator voltage to make sure it isn't dropping off causing a weak spark.
Not to question whther it's dialed in but i need to do that NOW and am interested in the process you used.
I have no useful input...except that it pretty much seems to be either the pump or spark .... or vacuum if you have any of the temp actuated valves.
Please make sure you update when you get it right.
