I removed the stock intake elbow to swap for the power one. Also I removed the intake tube going into the turbo so I could re-install my Airaid intake. There was a good residue of oil in the bottom of everything I removed. Ford did a fresh oil change when they did my headstuds and probably used the required 15 quarts like the book says. I usually use about 13.5 to 14 qts myself.
Question, how do I keep oil from getting into the intake and does this problem hurt the turbo ?
Its the 2nd post( sticky), under the Oasis requests on the first page. Mine was the same way, all sticky in the bottom of the intake tube, when I did the CCV reroute. Keep that crap from going thru the turbo! Mine could've been partially from the K&N oil the prev. owner had on it when I bought it. Scroll down to Crankcase Ventilation Reroute, and click on the link.
[QUOTE=John Kiernan]I removed the stock intake elbow to swap for the power one. Also I removed the intake tube going into the turbo so I could re-install my Airaid intake. There was a good residue of oil in the bottom of everything I removed. Ford did a fresh oil change when they did my headstuds and probably used the required 15 quarts like the book says. I usually use about 13.5 to 14 qts myself. QUOTE]
Did you check the level on the dipstick? If so, was it over the full hash mark?
Also, you can loosen the plug and drain some out if you want - just keep the plug up against the threaded drain hole and regulate flow with pressure on the plug. You need a wide pan under the plug and it is a little messy, but doable (I have done it on another vehicle). Ultimately, the Fumoto is the way to go.
