Poll: Mileage drop with ULSD?
Anyhow, here's the question:
Assuming no change in driving style, vehicle, location, etc..... all things otherwise being equal.... have you experienced a drop in mileage that you believe is due only to using ULSD?
Might be useful to post up which PSD you have.
Enjoy!
Also, just so we are all clear, I did not vote in this pole since I personally have not owned a PSD long enough.
I'm actually staying away from the stations that have confirmed they've switched but for other reasons - I'm not completely convinced yet that the new ULSD won't hasten the demise of the 8 very pricey injectors on each of my 7.3's - thanks to the Gov't/EPA all the "older" diesels are "injector wear guinea pigs" at our expense. I'm watching for news of "sudden injector failures" from folks out west that have been running ULSD for > 1yr.
DG
As far as I know all on road fueling stations have swapped over to ULSD year round now. Some are just too lazy to bother with getting their fuel tested to make sure it meets the standards (unless they emptied their tanks and re-filled with straight ULSD they had to test them before they put the sticker on to make sure the mix met ULSD requirements). I have heard that some stations in border states with Mexico haven't all switched yet but I'm not sure.
Like others have mentioned though, to me it is worth it to run either a blend of biodiesel, or an additive like OptiLube, Stanadyne, or Power Service in order to ensure that your fuel has enough lubrication. The government set a standard, and all fuel suppliers are suppose to add their own additive before shipping ULSD to the fueling stations in order to meet certain lubricity ratings, however you have to depend on them doing so. Also the government standard is below what most engine manufacuterers recommend, so I feel better by running an additive.
Also, people should note that as of the latest Ford Diesel Supplement manual that I have read, Ford does not recommend running more than 5% biodiesel, and could theoretically void your warranty if you do. I do not think it will happen, but I want to make sure people are aware of this. (A lot of stations around me have switched to 10-11% bio in order to keep costs lower, so I only get half a tank there and fill up at a straight diesel station when I can find them).
The point about Winter grade fuel and Summer grade fuel is well made. Additionally, the quality of fuel from any given supplier can make a large difference in mileage. (By large difference, I'm talking along the lines of around 1 mpg.) Because I monitor my mileage closely and generally fuel at the same hand full of stations, I noted that my mileage dropped upwards of 1 mpg when I got fuel from one particular major name supplier. The loss was consistent and repeatable. As a result, I no longer get fuel from that supplier.
Personally, I've been closely monitoring my mileage since the day I took delivery of my truck and can't say I've seen any difference between LSD and ULSD as far as mileage goes.
Here is a quote from member Awl_Bidness at a discussion at FTEs diesel forums.com. He is / was a Chemical Engineer
Here is what is going on with ULSD vs LSD: To sell into the commercial pipeline market at 15 ppm Sulfur, and to account for minor contamination in transit, refineries are generally targeting 8 ppm Sulfur from the Hydro Desulfurization units. In the last 5 years, refining has had to spend billions of dollars to "turn gasoline into gasoline" (drop S from 100 ppm to 30 ppm) and "turn diesel into diesel (drop S from 500 ppm to 15 ppm). In addition to the billions in capital cost, the operating costs increase and the production volumes decrease.....additional processing steps inevitably crack some materials to LPG and fuel gas which has a lower value.
LSD is typically heavier (higher distillation end point) than ULSD, and tends to be at a higher cetane value. Bottom line, the ULSD with a lower distillation curve will contain fewer BTU's per pound and thermodynamically will deliver less energy to the wheels. This is why you will usually see better economy with LSD vs ULSD. You will see the same shift in mileage from summer to winter in northern climates....when the cloud point has to shift below 20F in September or so for the winter season, the practical way to do that is to shift some kerosene to diesel in the fractionation processess. It keeps the fuel from clouding/gelling, but it also delivers less energy per pound of fuel.
