Dual fuel tank Problems
Old Feb 15, 2008 | 06:37 AM
PepperandSpice's Avatar
PepperandSpice
Angry Dual fuel tank Problems
Mornin' fellow Forders, I just purchased a 93 F150 5.0 4X4 with dual tanks. I'm currently running on the aux tank because the thing will not switch tanks. The fuel gauge moves when the internal switch is flipped but shows the front tank as empty, which is not true because I just spent $40 dollars to partially fill the tank.
Can anyone help?
Pepper
Old Feb 15, 2008 | 07:27 AM
TexasGuy001's Avatar
TexasGuy001
Its probably the float on the sending unit in that tank.
Old Feb 15, 2008 | 07:48 AM
Conanski's Avatar
Conanski
So are you saying the engine stalls when you switch tanks?
Old Feb 15, 2008 | 07:59 AM
subford's Avatar
subford
Yes a sunken float.
Old Feb 15, 2008 | 10:47 AM
PepperandSpice
The engine stalls just like it is out of fuel, so I was thinking that it was the tank solenoid gone bad, but I do not know where the solenoid is located to test it.
Thanks for the responses, however can someone help me in locating the solenoid?
Lost in Louisiana
Old Feb 15, 2008 | 10:54 AM
PepperandSpice
Hey Thanks a lot for the links too!!!
93 XLT 5.0 4 speed automatic
Old Feb 15, 2008 | 11:03 AM
subford's Avatar
subford
There is not any solenoid in your fuel system.
You have a pump in each tank and selected by the switch on the dash.
You have a bad in-tank pump or a bad switch on the dash.
Old Feb 15, 2008 | 03:47 PM
4x2mudder's Avatar
4x2mudder
i dont know about 1993's but i have and 89 and my fuel pump is mounted on my frame right below my drivers door. it might be in there or it could be in the line from the fuel pump to the switch
Old Feb 15, 2008 | 03:56 PM
jroehl's Avatar
jroehl
In either '91 or '92, Ford switch from a 2-pump system (low pressure in tank, high on frame, 2 low and one high if dual tank) to a one-pump system (high pressure pump in each tank.
Jason
