removing Grease from underside
Old Feb 14, 2008 | 08:12 PM
gecko5's Avatar
gecko5
I am in the process of cleaning the underside of my X. There seems to be a fairly large amount of what seems to be some form of hardened grease/grime on the frame rails.
What would be the best chemical from a cost / effectiveness perspective to get this off? I have tried a few now with little luck.
Cheers,
Old Feb 14, 2008 | 08:50 PM
VaSheriff's Avatar
VaSheriff
I would do it right..... scrape it off, sand the frame, apply primer, and then paint the frame.
Cost being...... scraper, sandpaper, primer, and paint.
Old Feb 14, 2008 | 08:59 PM
Btravelen's Avatar
Btravelen
Are you certain it's not the rust resistant wax coating that's applied to the frame during manufacture?
Old Feb 14, 2008 | 10:19 PM
H1449-6's Avatar
H1449-6
I don't know that it's wax but I'd bet you're right in identifying this as OEM.
OP, I'd suggest that you either leave it as is or pull the body off the frame an do the job right.
Old Feb 15, 2008 | 05:56 AM
gecko5's Avatar
gecko5
In order for me to seal off the frame, i cannot leave it on as POR15 will not adhere to it very well.
As much as i would love to do it this route, pulling the body off the frame is just not an option. I guess i will be doing it "Not Right"
Thanks for the advice though
78sharpshooter
28
Sep 7, 2009 10:47 PM
flcobra
16
Oct 1, 2008 09:20 PM
Dustin_86
16
Mar 3, 2006 12:57 AM
tsheriff
Feb 25, 2005 08:38 AM
Desert-Rat
Aug 21, 2004 12:40 AM
