Sponsored by: Real Truck
Weird Electrical Problem
Old Feb 14, 2008 | 07:37 PM
smokingjoe's Avatar
smokingjoe
Question Weird Electrical Problem
This is the weirdest thing. Yesterday my lights decided they were not going to go out when I turned the truck off. I had it on automatic. So, I tried to turn them off at the switch. No go. Then I unhooked battery #1. Lights are still on. I unhooked battery #2. Headlamps went off but all other lights stayed on. How can this be?
Old Feb 14, 2008 | 07:56 PM
F350-6's Avatar
F350-6
Unless you have some after market light set up that has a component that holds a charge for a short time or a solar charger plugged in, then the lights should go off with both batteries disconnected.
Old Feb 14, 2008 | 07:59 PM
smokingjoe's Avatar
smokingjoe
I agree. This is a wrecker. I know of nothing on it that would be holding a charge. The lights stay on after unhooking the battery until I turned the ignition again and then they went off. As of right now, they are off and I have both batteries unhooked. I thought this was technically impossible.
Old Feb 14, 2008 | 08:02 PM
zx250's Avatar
zx250
Of the next Riffraff East
Are you sure you don't have an extra battery for the extras on the wrecker. I know that on the emergancy vehicles, they sometimes have an extra battery for the extra lights and radios.
Old Feb 14, 2008 | 08:05 PM
smokingjoe's Avatar
smokingjoe
Not that I know of. But I will certainly do a little more research on that aspect tomorrow. That really is the only thing that makes sense. Only thing is, I think I've touched every inch of this truck at some time or another and can't remember ever seeing anything that would remotely resemble a battery other then the 2 under the hood.
Old Feb 14, 2008 | 08:06 PM
smokingjoe's Avatar
smokingjoe
Old Feb 14, 2008 | 08:15 PM
F350-6's Avatar
F350-6
Do you have something else to drive? Leave the lights running off of the mystery battery for a while and see how long it takes to drain down. See what else doesn't function properly with the dead mystery battery.
Or you could ask a local mechanic how much he charges to diagnose an electrical issue and then bet him that amount that you can make your lights stay on if he removes both batteries.
Old Feb 14, 2008 | 08:18 PM
zx250's Avatar
zx250
I bet you will find it somewhere in the bed around your wrecker controls. Even when you do find it, you still have to figure out why you are getting a feed back to you lights.
smokingjoe's Avatar
smokingjoe
It's a pretty vital piece of equipment for me so I don't want to discharge it on purpose. I was hoping someone had experienced this before. It defies science to me that a vehicle can have power when it's batteries are disconnected.
Old Feb 14, 2008 | 08:22 PM
zx250's Avatar
zx250
If you think about it, the winch and lift motors use a bunch of juice and it would be a bad thing if the wrecker I am depending on runs its batteries dead. For that reason alone I could see where the extra battery would be used for the lift motors.
Old Feb 14, 2008 | 08:24 PM
smokingjoe's Avatar
smokingjoe
I'll dig deeper tomorrow and let you know what I find. Thanks.
Old Feb 14, 2008 | 08:33 PM
F350-6's Avatar
F350-6
I would think the controls would only be operated when the truck was running, but Barry may be on to something here. With the batteries disconnected go play with the rear controls and see if you have any power there. That should narrow it down. If there is an extra battery or two for the tow controls it's better to find it now before they die.
Old Feb 14, 2008 | 08:38 PM
zx250's Avatar
zx250
Yes, let us know what you find. This has me puzzled as well.
Old Feb 14, 2008 | 09:34 PM
94yj's Avatar
94yj
if you have strobe lights it might be using what is left in the capacitor or do you have any rechargeable lights plugged in as zx said let us know what you find
Old Feb 15, 2008 | 10:26 PM
zx250's Avatar
zx250
Bump to see what you found.
