Quick timing help
Old Feb 14, 2008 | 05:06 PM
paintslinga2010's Avatar
paintslinga2010
Quick timing help
I got a timing light today and went out to try and use it.
So i made a mark on the 10 on the harmonic balancer, unplugged the spout, and fired up my truck which was already warm. It was pretty close lined up to what I think is the timing mark? It was like a metal piece over the balancer, i dont really know my haynes manual doesnt tell me ****. Can someone get me a picture of what the mark is supposed to be lined up with?
So anyway i get the line lined up and it runs great, smooth idle, and no shudder, so i shut it down, tighten the distributor, hook back up the spout, and fire her up a gain. It shudders a little like before and when i put the light on it, it is all spiratic, and the idle is kind of crappy.
Can anyone help me out? im new to this.
Old Feb 14, 2008 | 05:14 PM
jroehl's Avatar
jroehl
The timing pointer is a triangle. Put the 10º BTDC mark on the point. You do have to be careful when you tighten the distributor back down, as it's easy to tweak it a bit. Once the SPOUT is back in, the timing will jump around a bit as the computer messes around with the advance. As for the idle roughness, both of mine were always a little lopey.
Jason
Old Feb 14, 2008 | 05:22 PM
paintslinga2010
ok thanks, yeah i had it lined up with that triangle. This idle is bugging me, it makes the whol truck shudder, and sometimes it does it and other times it doesnt.
Old Feb 14, 2008 | 05:54 PM
quicklook2's Avatar
quicklook2
you did check it with the spout out right?
what year truck?
Old Feb 14, 2008 | 06:03 PM
paintslinga2010
Yes i had the spout out. Its an 89. The spout is right by the distributor, its just a little bar you pull out of the plug. correct me if im wrong. Thanks for the picture skan, that makes me feel alot better, because thats what i was lining it up with.
Old Feb 14, 2008 | 07:24 PM
quicklook2's Avatar
quicklook2
could need a tuneup.
Old Feb 14, 2008 | 07:31 PM
gamudslinger88's Avatar
gamudslinger88
Mine is doing the same thing. I just put a new motor in and I got it timed by ear and it has a light jerk to it at certin rpms. I am getting my timinglight back sat. and will shoot the timing. Does anyone have a pic of the spout yall are talking about. Ohh the cam I am running has a slight lope to it and I think that amplifies the problem.
Old Feb 14, 2008 | 09:14 PM
paintslinga2010
I tuned it up not even 500 miles ago, but i did use autolite platinums. Maybe the source?
Old Feb 14, 2008 | 09:18 PM
quicklook2's Avatar
quicklook2
use motorcraft copper plugs.
bet when you take those plats out 3 or more will be fouled.
DJdemon6696's Avatar
DJdemon6696
a shudder usually means dirty injectors ( when i worked at the dealers ship.. ) SO if yours is recently tuned up.. maybe the injectors is dirty.. try diong a cleanup with seafoam... halve can trhu brake booster and halve can in the tank..
but for our old trucks its kind of normal.. mine does has kind of a small vibration when idling.. its normal i think
