Grille Lights
Old Feb 14, 2008 | 04:29 PM
newt79-99's Avatar
newt79-99
Grille Lights
Anyone install or have pics of lights mounted behind the grille on their trucks? I saw a Ford on youtube.com with lights mounted on the core support and it looked good. Thanks!
Old Feb 14, 2008 | 07:41 PM
Twinsdad98's Avatar
Twinsdad98
A few guys on this forum have. Check out Black04Lariats gallery. He has.
Old Feb 15, 2008 | 03:06 AM
jonney_boy's Avatar
jonney_boy
I am just working on installing lights behind the grill on my '07 f-150. Driving lights are done (behind the grill) and the fog lights will be started soon.
I didn't take too many pics and most of the pics I did take where in really bad lighting conditions (rain + snow + night time). It should give you a good idea what to expect tho.
First off, this is the "completed" shot. The lights are Hella FF1000's with 100w bulbs in them. They are covered using a clear protective cover (also sold by hella).
There is plenty of room in behind our grills to mount "huge" lights. One thing I did try to do with this install is to minimize drilling into the truck, so, all mounts are done with existing holes. Keep in mind that I do have access to a welder so many of the brackets can be "custom fit" with a bit of time and a angle grinder.
After looking around for a bit, I figured the easiest way to was to bring 2 vertical supports up from the end bracket on the trucks frame. From this bracket, a 1" square tube was brought up vertically and then a piece of angle iron bolted to it. This give me a level surface to mounts the lights onto.
As you can see in this picture, the bottom of the hella's are mounted at about the same height as the bottom of the headlamps. The horizontal angle iron provides a great mounting spot for any accessories you want to mount (like Hella FF1000's and 2 pairs of supertones in my case). The 2 shiny bolts on either end is where the bar attaches to the vertical support. This was done so the entire bar can be easily removed with only 2 bolts. All the electrical has been done with quick connects as to ease removal.
Here is a picture of the vertical support with the bar removed. This is the passenger side, looking straight down from the hood.
If you look carefully at your own truck, you will notice that that area I have the back plate bolted to is really a "cupped" shaped piece of metal. I cut a 1/4 piece of steel plate to match the shape of the flat area of this cup, spaced it back another 1/2" then attached the 1" square tube to this.
Here is a shot of the front plate that is used to sandwich the factory bracket.
The same is done on the drivers side.
the mount is rock solid. I can move the entire truck up and down, left and right if I grab the bar and there is no flex.
Old Feb 15, 2008 | 01:18 PM
Truck Stuff's Avatar
Truck Stuff
thats a nice setup. you could do something like that or you could just get this
383.45 shipped for halogen.....
http://www.buyautotruckaccessories.c...lliary-grille/
tjdad62
Aug 19, 2011 05:42 PM
djfordman81005
1997 - 2003 F150
Dec 9, 2007 08:50 PM
godtar
2004 - 2008 F150
Feb 12, 2007 11:32 AM
Patatoe1
1997 - 2003 F150
29
Dec 22, 2005 05:54 PM
