Sponsored by: Innova
01 F250 reverse wire
Old Feb 14, 2008 | 03:26 PM
timmycrf's Avatar
timmycrf
Question 01 F250 reverse wire
Trying to hook up my reverse camera to turn on when i put the truck in reverse, i've had it on a manual switch but wanting a hands free trigger. I'm looking for a 12v trigger wire under the dash, reverse lamps don't have a seperate circuit in the fuse panel and i'm not real wild about running wiring to the back of the truck. Thanks for your help
Old Feb 14, 2008 | 04:57 PM
sirthomas's Avatar
sirthomas
all the wires for the tow plug should come up in a harness under the master cyl. I just traced mine from the plug forward to see where they came up to the fuse block
Old Feb 14, 2008 | 07:14 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Wiring and Maint Manual here:
http://www.bedlib.org/ebsco.html
Use the word "library" for both the user name and password.
Wiil a MOD PLEASE put this link on a sticky??? Thanks
Old Feb 14, 2008 | 11:21 PM
KCAsound's Avatar
KCAsound
Reverse wire on the 2001 shows to be a black with pink stripe wire located in a 12 pin gray connector just below the master cylinder.
Old Feb 14, 2008 | 11:25 PM
timmycrf's Avatar
timmycrf
found it, thanks to everyone for the information. much appreciated
Old Feb 15, 2008 | 02:56 PM
Beerstalker's Avatar
Beerstalker
Just in case somebody finds this with a search, I'm not sure about the 2001 but in my 2007 (which should be the same as 2005 and 2006 models) has the reverse wire as a black wire with pink stripe at the lower passenger side corner of the fuse block under the steering wheel. I have a picture of the wire where I tapped into it in my gallery for Audio Mods.
corksil
May 12, 2020 08:39 AM
BlueOx460
Mar 29, 2017 07:17 PM
nagetech
Aug 23, 2015 11:19 AM
chi6488
6.4L Power Stroke Diesel
13
Jun 12, 2012 03:21 PM
Pharticus
Jan 18, 2012 06:42 PM
