hub conversion help please
Ok 95 4x4,auto hubs with 3 screw cap. Want to change to manual. Bought the warn hubs AND the kit as sugested for the 3 screw cap(lock washers & nuts).
Problem is when I took out the auto stuff I noticed that there were NONE of the 3 thrust washers OR the C ring that goes in the slot about a inch and half from the outter end of the shaft. The auto hubs were inop when I bought the truck. Now are those needed and if so where can I get them. Parts missing are #12,13,18,19
Any help please?
Thanks
<!-- google_ad_section_end -->
Hello and welcome.
I can't help you on this one, but I can suggest you search the forum. A few days ago someone was converting from auto to manual hubs, and he could not get everything together with the washers. There was some discussion about it, and he ended up leaving them out. Seems like the instructions were not the best. Don't know if your situation is the same, but never hurts to do a search. there is a ton of info available in old threads.
Good Luck Frank
Good Luck Frank
. . . . . You are going to need to READ the instruction's REALLY carefully>>>>>>> it is stated,,,,," IF you are changing over to WARN Manual's from the =3-screw_cap Auto-Hub's, YOU WILL NEED TO have the Spindle Nut Conversion Kit " as well, FIRST ! ! ! ........and then you can follow that link for what " fmr9 " has given for ya on the earlier post .......{ i even have some Techi-Help on this with/pic's in my Gallery_album in my sig....}
mr. Charles
mr. Charles
cman1120
27
Feb 28, 2022 01:07 PM
Rokcrln
59
Feb 25, 2017 05:50 PM
TruckNorris250
46
Sep 10, 2015 10:39 PM
dferrell5
Dec 18, 2013 10:04 AM
Seabiscuit
Mar 17, 2009 08:48 AM
