help
Old Feb 14, 2008 | 05:40 AM
str8racing's Avatar
str8racing
help
Does anyone have the wiring diagram for my front gas tank circuit? Guage does not work and it's my primary tank.The back tank works but it leaks around where hose goes into tank. I'm trying to find the proper hose as this one does not fit around lip at tank. Also is there adjustment for the indicator that tells you what gear you're in?Mine has to be put on n N for OD. Thanks.
Old Feb 15, 2008 | 04:07 PM
str8racing's Avatar
str8racing
i need help!!!!!!!!!!!!
Old Feb 15, 2008 | 04:11 PM
19FORD93's Avatar
19FORD93
I'm not sure about the fuel tank wiring diagram but if you take your dash bezel off and on the ride side of the steering wheel there will be either a black or white thing that looks like a gear, when you spin that it adjusts where the indicator lines up with the letter on the shifter. Its a real simple fix. Good luck with the gas tank.
Old Feb 15, 2008 | 04:43 PM
str8racing's Avatar
str8racing
thank you , i'll fix tomorrow.
Old Feb 15, 2008 | 04:52 PM
flareside_thunder's Avatar
flareside_thunder
do a member search for subford.....he's got pretty much every diagram you could ever want or need......Hope this helps.
JR
