having major trouble
Old Feb 13, 2008 | 09:15 PM
f-350 strong's Avatar
f-350 strong
i need some advice. well i just bought a f350 and i had it about two weeks running great. well they said there was bad diesel going around my state so i went to the next state over. well soon as i got gas it wouldnt start. but eventually it did. well i had the problem again so i had the fuel filters changed. well that worked for about 4 hours then it started to die and blow heavy amounts of smoke out the exhaust. just wondering if you have any advice out there on what this could be. thanks
Old Feb 13, 2008 | 09:22 PM
npccpartsman's Avatar
npccpartsman
It sounds like your EGR valve is stuck or needs cleaning or your turbo veins are sticking. I'd pull the EGR valve and clean it with CARB. cleaner (not brake cleaner) and reinstall it. If that doesn't help it may be the turbo veins sticking. If you're under the 5yr/100K mileage mark it's still under warranty.
Old Feb 13, 2008 | 09:55 PM
F250tuff's Avatar
F250tuff
Make sure you don't get the carb cleaner down into the weep holes of the EGR valve.
Old Feb 14, 2008 | 01:45 AM
run6.0run's Avatar
run6.0run
Does it start up and run when cold????? If so you could have a high pressure oil problem. What color is the smoke???? white or blue or black
Old Feb 14, 2008 | 09:15 AM
f-350 strong
had it looked at still dont know tho
well i had it looked at. right now they are saying cylinders 3 and 5 have failed. and the smoke was a white color. does that mean the injectors have failed? thanks
90coupedraggn
Aug 12, 2013 08:22 PM
Calamity Cowboy
Mar 17, 2013 03:32 PM
gregndmac
40
Feb 5, 2012 06:34 PM
PAPA Tony
Mar 26, 2011 04:28 PM
rkbutz55
Jan 5, 2011 12:08 PM
