4x4 problem
Old Feb 13, 2008 | 08:48 PM
ggranger's Avatar
ggranger
4x4 problem
I went to put my 06 Ford Ranger FX4 inbto 4x4 last night and it did not imeediately engage. I drove about 1/4 mile and it finally engaged.
After that I continually switched from 4x4 H and 4x4 L and back into 2wheel drive and had no problems.
Wondering what the problem could be.
Old Feb 14, 2008 | 11:10 PM
ggranger's Avatar
ggranger
Anybody?//////////////
Old Feb 14, 2008 | 11:41 PM
littleme13's Avatar
littleme13
how often do yoiu use 4x4??? if its not very you need to use it more. the sielenoids dont like sitting. if they do they break or dont like to work.
Old Feb 15, 2008 | 11:10 AM
wendell borror's Avatar
wendell borror
Amen to that. Use your 4x4 at least once a month in both ranges. Even if you just go back and fourth in the driveway. The electric shift motors will gum up from not being used. Even if you have a mile or two of straight road, throw it into 4 hi, use 4 low in the driveway or a round in the yard if need be. There's guy's that go for years without using the 4x4 and get mad when it doesn't work, if you don't use it, you can loose it. Also in your case it might of been iced up a little.
Old Feb 15, 2008 | 05:24 PM
ggranger's Avatar
ggranger
Thanks for the feedback.......I rarely use the 4x4, so yes, it has been neglected for awhile...........
I called Frod and they said to make sure I put it in 4x4 at least once a month just as you have suggested....
I just wish they would mention this kind of stuff in the manual!!!
Thanks again for the feedback....I am sure I will have many more dumb questions....I am not mechanically inclined......
Old Feb 16, 2008 | 12:16 PM
ggranger's Avatar
ggranger
I have been researching this issue since I have run into it........seems as though it is a very common problem.......
Makes me wish I had the option of a manual 4x4 engagement........
It's a shame a little motor can prevent a costly 4x4 system that I paid for from working.....
....but I still love my little Ranger!!!!!!
Old Apr 9, 2009 | 11:16 AM
ggranger's Avatar
ggranger
Well...........the 4x4 motor was bad after all.........has been replaced.
Old Apr 9, 2009 | 12:01 PM
Foxxy's Avatar
Foxxy
lil ms. innocent
This is definitely good to know. Looks like I better start doing it myself!
Old Apr 9, 2009 | 07:35 PM
bazzman1953's Avatar
bazzman1953
Or you can go pop the bucks to convert it to manual and never have that particular again. That's a simple enough change that it can be done in a couple of hours at your convience. The only special tool will be the socket needed to loosen/tighten the lock nuts.
Old Apr 10, 2009 | 06:04 AM
wendell borror
Yeah, thats what I though as well. Then I read that the 4wd system operates through the computer somehow. It you swap to a manual T-case it causes the puter to go nuts. I've been meaning to talk to Doug at bama chips to see if the T-case can be deleted from the computer with a bama engine programer. I never thought the t-case would cause a computer issue, but according to the article I read it does. I don't even remember where I read it or I would post it. However, I know for sure I read it somewhere. I guess we could allways get the computer from an 02, or 03 FX4 level II that had the manual T-case. Ford still sells them , I checked as I was serious about doing this swap and still am. I just need to gather up my info and parts.
