97 explorer trac con problem
- check the air pressure in all 4 tires, must be same rolling circumferance
- pull the hall sensors (2) from the T/C, check and clean.
- change ATF in T/C, make sure the fill lug will unscew before opening drain.
By | 2026-06-12 11:01:55
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
