Sponsored by: Real Truck
tire size speedo issues
Old Feb 13, 2008 | 07:47 PM
shamrock442's Avatar
shamrock442
just upgraded from 18 inch rims to 20 inch xd revolvers with 37 inch tires does anyone make a speedo calibration programer? heard some programers can do 35 inch tires i have a 2006 f350 diesel. thanks mike
Old Feb 13, 2008 | 08:09 PM
Beerstalker's Avatar
Beerstalker
For that size you will have to go with something like the Superlift Tru-Speed. I think there are a couple other similar items, but that is the one that gets mentioned the most here.
Old Feb 28, 2008 | 02:24 PM
Mercury45's Avatar
Mercury45
theres something called an accupro
its a programmer...
I use a merlin controls speed wizard, its the most user friendly
good luck
kenny
Old Feb 28, 2008 | 02:45 PM
Layson's Avatar
Layson
Super lift truespeed!!
Old Feb 28, 2008 | 03:38 PM
Mercury45's Avatar
Mercury45
whats the tru-speed going for now these days?
Does it work with 2008's?
I know the guys at merlin and they have tested theirs on 08's already
good luck with whatever you choose, if you need help with the wiring let me know
kenny
Old Feb 28, 2008 | 06:14 PM
RckyMntnKng's Avatar
RckyMntnKng
If you buy one and recal your speedo for tire size, will that also filter into your
MPG computer etc? I know that thing is just using so many revs/mile (based on stock tire size) and when you jump tire size you are traveling farther than a mile for the same revs...thus telling you you are getting worse mileage than you really are..
Old Feb 28, 2008 | 06:21 PM
Mercury45's Avatar
Mercury45
good question and here is the answer
2005 UP Superduty trucks MUST be hooked up right after the ABS module, it is the only way to insure the speed signal is corrected to the speedometer, since the speedometer is driven off the PCM. However on 2005 + trucks the PCM drives the cluster via a "CAN" signal so it is not a "speed wire"
Now for 99-04 it is suggested that the user hook up the device right after the abs module. (Actually the speed wizard gives the user the option, but I am pretty sure they want to change their manual for any new installs on 99-04). Anyway on 99-04 the user can hook it up right after the ABS module, and this will correct the speed to the PCM which then also goes to the over head console.
Or on 99-04 they can hook it up right before the cluster (it will only correct speed into the cluster - not recommended any more since over head consoles and such use the speed signal).
But in any case - to answer your question - the speed signal will be corrected for ALL aspects of the speed circuit, depending on where it is spliced in.
I hope that helps.
(edit) would also like to add that those overhead MPG calculators are about the most innaccurate thing I have ever personally dealt with(end edit)
kenny
