Sponsored by: Auxito
Does your window. . .
Old Feb 13, 2008 | 04:07 PM
DanK5's Avatar
DanK5
Driver's side window freeze shut if it's cold outside? No ice- just cold. I can't roll mine down when it's cold out until I run the heater for awhile. Anyone with a solution? I can't figure out where it gets hung at. I put pressure on the roll down handle and beat all around the perimeter of the glass to try anf break it free but nothing.
Thanks.
Old Feb 13, 2008 | 04:15 PM
Johnnyboy1979's Avatar
Johnnyboy1979
I would say water is getting inside the door somehow and icing up the regulator or something.
Old Feb 13, 2008 | 05:08 PM
ididntdoit99's Avatar
ididntdoit99
Mine does it... I beat the crap outta it til it moves.
Old Feb 13, 2008 | 07:46 PM
steve(ill)'s Avatar
steve(ill)
i would start by shooting some type of silicone spray in the window track on the upper half of the door (where the window sets when closed). see if that helps. if it still does it, then might be inside the door. i dont think the "inside of the door" warms up much when the heater is on a short time.
Old Feb 14, 2008 | 03:14 AM
slowr w/o blowr's Avatar
slowr w/o blowr
i have had the window freeze up on my 98 150, its usually the outer weather stripping on the bottom side of the window opening. i have a plastic putty knife and slide along the stripping and usually it opens up just fine.
Old Feb 14, 2008 | 10:47 AM
DanK5's Avatar
DanK5
Thanks guys for the ideas.
Old Feb 14, 2008 | 12:18 PM
northernowl's Avatar
northernowl
Mine freezes at the outer weather stripping at the bottom. You usually don't notice this unless you try to roll the window down shortly after you been sittiing a while. Mine usually takes about a good half hour to thaw by itself with the heater on.
Old Feb 17, 2008 | 10:44 AM
tampa898's Avatar
tampa898
I don't think I have ever owned a vehicle where this did not happen in the winter months. I do know that forcing it is a good way to really screw up the window.
Redneckfordf2502002
Sep 27, 2023 05:05 PM
bigtuna
Nov 30, 2013 02:10 PM
deborah3077
2004 - 2008 F150
Mar 8, 2012 06:49 PM
AZSANDMAN
2004 - 2008 F150
Feb 18, 2007 04:31 PM
dvsmnstr
Jan 19, 2004 02:27 PM
