please help
Old Feb 13, 2008 | 02:33 PM
8inav's Avatar
8inav
please help
ok, on my way to lab this morning my truck started bucking and the check engine light kept flickering. figured it was a bad ground and tryed making it to class to where i could fix it. got about 10 min from the auto lab and it finally up and died. got a tug into the lab from my buddys 99 PS. had three codes in the pcm. P0344 and P0347. cam sensor intermittent and cam sensor failure. the third code was from the 15K mod from a couple weeks ago when i was hammerin up a steep hill(fuel pressure too high or too low forgot the code number). replaced the cam sensor and test drove the truck, ran fine no skipps and no light. got home from class and let the truck idle while i filled my stove and came out to hear it not running. i heard a clicking coming from under the hood opened it and it was the #2 relay in the power distrabution box. mil flickering again also. much more rapidly than earlier in the day. relay #2 is for the injector modual i think, and does a clicking relay indicate a bad ground. also does anyone know where the ground location is for the #2 relay. the owners manual is helpful but not that helpful. this is the second time in six days that my truck hasent made it home on its own power, the fuel pump went out last friday any help will be much apprieciated, cody
Old Feb 13, 2008 | 02:42 PM
8inav's Avatar
8inav
probably should tell you guys what the truck is huh, its a 97 f250 w/ a five speed if you need more let me know thank a bunch you guys have so much good info
Old Feb 13, 2008 | 02:44 PM
tjbeggs's Avatar
tjbeggs
So does it not start and run now? usually clicking relays are from low voltage.
Old Feb 13, 2008 | 03:05 PM
8inav's Avatar
8inav
no the truck wont start, the mil is on and flickering, the truck will fire then die
Old Feb 13, 2008 | 03:49 PM
Hussler's Avatar
Hussler
Clicking relay .. probably a short somewhere. I would try unplugging things while it's clicking. Start with your new CPS first.
Jim
Old Feb 13, 2008 | 04:09 PM
8inav's Avatar
8inav
unplugged the cmp sensor still clicked, wiggeled lots of wires still clicking, went inside cab to check over the owners manual and turned key on an tried starting it, it fired and died now check eng light is on stedy and no more clicking.
Old Feb 13, 2008 | 04:56 PM
Action4478's Avatar
Action4478
CEL on all the time is not good ,,are you getting a WTS light?...
You may want to un hook the PCM ,make sure the connection is good ....
PCM location ....Here ....
Old Feb 13, 2008 | 04:58 PM
Action4478's Avatar
Action4478
Try switching the position of the small relays around also
Do 1 test at a time so you know what works ...
Old Feb 13, 2008 | 06:08 PM
8inav's Avatar
8inav
what is the CEL? the wait to start light is working as normal. the relay went back to clicking and the mil went back to flickering. i tried changing the relays around earlier when it was clicking and it didnt make a difference. and thanks a bunch for the picks, i had the IDM and the PCM backwards. ill try unhooking the pcm next. thanks again
Old Feb 13, 2008 | 06:36 PM
Hussler's Avatar
Hussler
CEL is "Check Engine Light" .. what is "mil" that is flashing ? Education please
Old Feb 13, 2008 | 07:02 PM
Hussler's Avatar
Hussler
One more dumb question .. have you cheked your oil level ? OK two questions .. are you indicating the relay clicks with ignition key in you pocket or only in the run and not start position ? Sorry that was not clear in your response.
Jim
Old Feb 13, 2008 | 08:13 PM
Byrddog's Avatar
Byrddog
Yeah, what is mil???
Old Feb 14, 2008 | 08:26 AM
8inav's Avatar
8inav
sorry guys. mil to me is malfunction indicator lamp. sorry ther are way too many abrievieations out there. when i was milking this morning i finally understood cel. but anyways i think i found the prob. the plugin at the back of the DP tuner must have been loose. truck started fine after i got the 3M tape off and screwed with the connector. thank a bunch again, hopefully i'll lern the different abrieviations.
Old Feb 14, 2008 | 08:36 AM
Action4478's Avatar
Action4478
.....This ....may help...
Old Feb 14, 2008 | 03:59 PM
8inav's Avatar
8inav
thanks alot for all the help again, i apprieciate all the help.
drivewayford
1997 - 2003 F150
Apr 6, 2014 11:46 PM
12valveEx
Aug 16, 2013 08:24 PM
terry henderson
1997 - 2003 F150
Jan 12, 2012 10:17 PM
P1ckup Man
19
Jan 15, 2010 10:23 AM
Andy_Paul
Electrical Systems/Wiring
Jul 16, 2003 09:30 PM
