Please Decode My VIN
Old Jan 26, 2009 | 12:50 AM
jpbuch's Avatar
jpbuch
decoding a 1964? ford pick-up vin #
Lost for info! Anyone know how to fig out what this vin# means F25br484039? Much appreciated.
Old Jan 26, 2009 | 01:09 AM
camperspecial65's Avatar
camperspecial65
Its an F series 3/4 ton 2WD truck built in San Jose in Dec. 1963...its a 1964 model...has a 1 bbl carb...good for 150 hp
F= F series truck...conventional cab
25 = 3/4 ton 2WD
B = 262 6 cyl. 1 bbl carb
R = built @ San Jose, Ca
484039 = Dec 1963 build date
- cs65
Old Jan 26, 2009 | 02:12 AM
jpbuch's Avatar
jpbuch
ford vin decode
Thanks for that! So it isn't a 4x4 as advertised.
Old Jan 26, 2009 | 03:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First three digits of the VIN.
F25 = F250 2WD / F26 = F250 4WD
Where did you find this VIN (F25BR484039), on the registration or off the Warranty Plate, located on the left door face below the latch?
Old Jan 26, 2009 | 12:36 PM
jpbuch's Avatar
jpbuch
re; check-out the vin # (before) buying!
I was about to buy a 1964 4x4 flatbed from a private party in Salem Or, but decided to first get help from this forum decoding the vin#. Some things didn't add up. One pic showed an odd (quite vertical) steering column angle and the grille was from a '66. It turned out that the '64 was actually a '63 4x2 that had been converted into a 4x4. Not saying it wouldn't work as a local driver but It wouldn't have passed the provincial safety inspection required of me to import the vehicle into Canada for licencing. Thanks to the numerous respondants. Nothing like information to help make the 'right' decision. Great resource forum. Thanks again!
Old May 30, 2011 | 07:06 PM
jimsford truck's Avatar
jimsford truck
need some help to decode my vin number on my 66 ford truck can anyone do this the tag on door is to bad to read
Old May 31, 2011 | 08:42 AM
NumberDummy
Post the puppy here, or start a new thread...someone will decode it for you. Also post all the codes found on the Warranty Plate, located on the left door face below the latch.
nerksa
May 21, 2013 09:39 PM
6cannons
Mar 11, 2013 07:47 AM
E-Mo
Sep 17, 2011 07:39 PM
Rangerdanger33
1983 - 2012 Ranger & B-Series
Jul 18, 2005 06:37 AM
trouble
Aug 17, 2002 11:41 PM
