400 Intake gasket???
Old Jan 3, 2003 | 01:32 AM
telesqrt's Avatar
telesqrt
Old Jan 9, 2003 | 11:47 AM
JJDDOOGG's Avatar
JJDDOOGG
Im ready to put my weiand intake on (w/o egr) and Ive got two intake gaskets to choose from. A valley pan gasket and a typical intake gasket. Both are from felpro. Do I have to use the valley pan with my weiand intake? There are no opening or ports in the bottom.
My stock intake had a bid threaded plug in the bottom but no visible openings. Any ideas which one to use??
Thanks, Jaret
Old Jan 9, 2003 | 05:37 PM
shazam's Avatar
shazam
If it was my engine and it was going to be street driven, I'd put the pan gasket and use silocone instead of the rubber end gaskets.
The pan gasket will help to keep the hot oil off the bottom of the intake which will help keep the intake charge cooler.
Old Jan 9, 2003 | 10:21 PM
JJDDOOGG's Avatar
JJDDOOGG
Thanks for the info. You always have some good input and insight.
It seems like the valley pan would not seal as well as the other gasket. Just not used to it I guess. Thanks, Jaret
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
