Engine Cradle
Old Feb 13, 2008 | 11:01 AM
77ford guy's Avatar
77ford guy
Question Engine Cradle
Hey! I got a hi comp 460 in one of my trucks that i'm gonna haul to the dump, and i wanna pull the motor and save it in my shop for when my 400m blows in my 77. Does anyone know the dimentions of the motor mounts? I want to weld together a rolling engine cradle to store it on and didnt know how big to make it. Thanks for any help with this non typical question.
Old Feb 13, 2008 | 11:35 AM
cobraguy's Avatar
cobraguy
I have a 460 pallet at home I'll get dimensions after work and post them for you later today.
Old Feb 13, 2008 | 04:38 PM
77ford guy's Avatar
77ford guy
Thanks! Id really appreciate it!
Old Feb 14, 2008 | 05:57 PM
cobraguy's Avatar
cobraguy
OK its basically two 2x12 on edge 9 1/2" apart 21" long it holds a 460 on the oil pan rail. The ends are open. If you have an oil pan you could use it for a pattern. I've seen some universal ones made on a dolly platform with two slotted rails. Four 10" pieces of 3/4" pipe with a large nut welded in one end and a piece of angle iron welded to the other end could slide along the rail to accommodate any engine.
