Timing Chain
Old Jan 9, 2003 | 04:49 PM
Green Streak's Avatar
Green Streak
Timing Chain
I have a stock 79 351m. I will be replacing the timing chain this weekend. A double roller is four timrs the price of the stock single replacement. Anyone run one of these on a stock motor. Any comments about this, I will be modifying the engine in the not too near future
Thanks in advance
greg
Old Jan 9, 2003 | 05:01 PM
D9351's Avatar
D9351
Timing Chain
I think that the problem with a "stock" gear is that it is retarded a couple of degrees. If you see that it has a choice of three keyways or something like that (to allow adjustment), then maybe it's OK.
I'm sure a tighter chain is better than a loose one, but I don't know if the double roller stays tighter longer or not.
Was that unclear enough?
Old Jan 9, 2003 | 05:22 PM
shazam's Avatar
shazam
Timing Chain
I'd use the double roller chain set just to undue the retarding of the cam that the stock chain set has.By advancing the time that 4 to 8 dreg.'s it just might be worth the extra cost of the timing set for the extra boost to the pants you feel when you get on it.
Old Jan 10, 2003 | 10:31 AM
dbarracuda's Avatar
dbarracuda
Timing Chain
hey guys
I have a 77 f150 w/400 and i have been considering replacing the timing chain cause iwas told it would open up the stock cam. How does replacing the timing chain affect gas mileage?
Thanks
David
Old Jan 10, 2003 | 10:34 AM
dustinleavitt2000's Avatar
dustinleavitt2000
Timing Chain
if you get a single roller timing set just make sure its not the one with the plastic coating on it. I just tore down my engine and the plastic teeth had worn off and there was plastic inside my oil pan, it was jumping time and i think It helped fry my cam bearing.
Old Jan 10, 2003 | 12:56 PM
PhordPh250's Avatar
PhordPh250
Timing Chain
Personally,
If your rebuilding in the not too distant future I would save the bucks and not go with the double roller till I did my rebuild...."Stock" usually only means from Ford..anything you buy from JC Whitney or Summit Racing will allow you to set the timing +4 0 or -4 and their pretty cheap. I wouldnt put a used timing chain in a full rebuild.
Old Jan 10, 2003 | 10:27 PM
F250 1979's Avatar
F250 1979
Timing Chain
dcberg
Jan 21, 2013 09:10 AM
johnson2007
Feb 8, 2011 06:40 PM
Patrick2010
Jan 28, 2011 04:42 PM
limptera13
Mar 27, 2010 07:57 PM
lorenr
Nov 13, 2005 08:44 PM
