Oil consumption
Old Feb 23, 2008 | 08:31 AM
cals70mach's Avatar
cals70mach
do you have the part # for the oring and the part # for the rubber hose that go's to the CDR and the vally pan thanks
Old Feb 23, 2008 | 08:50 AM
uchitz's Avatar
uchitz
No, sorry, but the "stealer" should be able to help you.........
Old Feb 23, 2008 | 09:17 AM
kevbits's Avatar
kevbits
Ya, my tuck drank the oil. I would have to add about 2 qts about every 500-700 miles. I have driven about 450 miles since i replaced the CDR valve and and rubber washer and my oil level is right where it should be.
Old Feb 23, 2008 | 10:02 AM
PLC7.3's Avatar
PLC7.3
My last valley pan to CDR pipe was all one piece I believe........check out this #
The part # for the rubber tube on the CDR... Retainer # E8TZ 6A892A
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A
IH part #1805319C1
These guys usually sell them too....... call them.
http://www.mstechinc.com/shopsite_sc/smarthtml/ford.asp
Old Feb 23, 2008 | 10:19 AM
cals70mach's Avatar
cals70mach
IH part #1805319C1 is this the oring or the tube
Old Feb 23, 2008 | 12:00 PM
uchitz's Avatar
uchitz
Thanks guys, your information was very helpful. Kevbits, your consumption is about what I use. I'm glad I havn't done the valve stem seal yet. Will get and install these parts next month!
