problem with turn signal
Old Feb 12, 2008 | 09:00 PM
chiefn10's Avatar
chiefn10
so today i install carpet in my 99 F-350, and all of the sudden my turn signals don't work. my plashers work fine. i tried looking in the owners manual for a fuse #, but didn't see one dedicated to just the turn signals. any suggestions?
Old Feb 12, 2008 | 09:39 PM
DieselCamper01's Avatar
DieselCamper01
This is just a WAG but were you tucking way up behind the pedals where maybe you could have bumped a plug. Sorry this is not very specific just taking a stab at a guess. I am not sure where the wiring is exactly routed.
Old Feb 12, 2008 | 10:29 PM
chiefn10's Avatar
chiefn10
good possibility that is it. dark here now, but can try and check it tomorrow.
Old Feb 13, 2008 | 07:32 PM
chiefn10's Avatar
chiefn10
everything looks good. my haynes manual says to check the turn signal and flasher fuse/relay. according to the owners manual, there isn't a fuse dedicated to the turn signal only, just one for towing. again, the flashers work fine, so i am a bit confused.
Old Feb 13, 2008 | 08:25 PM
F350-6's Avatar
F350-6
Have you checked fuses 1 & 23 labeled electronic flasher?
Old Feb 13, 2008 | 08:26 PM
chiefn10's Avatar
chiefn10
no, but i will right now.
Old Feb 13, 2008 | 08:40 PM
guitarpicr's Avatar
guitarpicr
Dont know @ the Fords but my wifes blazer had a flasher canister for the emergencyflashers and a seperate one for the blinkers.
Old Feb 15, 2008 | 04:37 PM
davhut's Avatar
davhut
Ok, so am I correct if I say that your hazard flasher circuit works as it should, with both right & left, front and rear lights flashing but when you try right or left turn signal you get nothing front & rear?
