Air Bag Light
Old Nov 23, 2007 | 01:52 PM
green 69's Avatar
green 69
Air Bag Light
Hi there, I have a airbag dash light on, it flashes code 32
can anybody tell me about this code is and what the problem may be. also now that the airbag light is on the cruise control and horn don't work all fuses are good
can't find a link between the too..
Help anybody?
Old Nov 23, 2007 | 01:57 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
im going to give shot in the dark. maybe you clock spring, or a connector? since they all go the same way, take your column apart and check the connectors
Old Nov 23, 2007 | 03:23 PM
green 69's Avatar
green 69
Air Bag light
Thanks for the info: so i took the clock spring apart, looked at the connections, found nothing wrong, all connectors
in and tight.
Old Feb 15, 2008 | 03:54 PM
baloo83's Avatar
baloo83
I got the 32 code and i pulled the fuse to check it to see if it was blown but it was good. when i reinstalled and started the truck up again, it was cleared and didn't come back. now the light comes on in the self check and goes out like it should.
Old Feb 15, 2008 | 04:57 PM
green 69's Avatar
green 69
Thanks for the info, Where is this fuse located, I went thru all the fuses but might have missed it..
