I got a slight ping.
Old Feb 12, 2008 | 08:48 PM
bubbas78f250's Avatar
bubbas78f250
Hi all I am new around hear. Been reading a while but not finding the help I need.
I have a 78 F-250 with a 351m from a 79. I bought all the parts from tmeyerinc to turn it into a 400 using stock heads. Very mild cam, holley 670 truck avenger carb.
I got it together and in the process of breaking it in I found it ping in third and four under load. I had stock plugs in it, went to a range cooler and it helped. Checked my timing and put it at the factory 6 degs bftdc and thaat help. 'was at about 8 or 9. I talked to holley and they told me to go up in jet size that that carb needed a little tweak to run well on a 410. ' .040 overbore'
I went from a 68 jet to a 70 no difference. Should I back the timing of more?
I am running 87 octane gas witch i want to stay with. I have been told that I can run that gas with under 9.5 to 1 com. And Ideas?????
Thanks
Bubba
Old Feb 12, 2008 | 09:03 PM
ford_boy_1996's Avatar
ford_boy_1996
I think you should play with the timing
Old Feb 12, 2008 | 10:09 PM
hollenjoe's Avatar
hollenjoe
what about bigger jets, try also 91 octane... if you are using tims 0 deck with a 40 overbore and shaved some how your heads, yo should be around 9.8 to 1 and with the open chambers, you will ping with anything under 91 octane...
besides 6 btc is really retarded....
Old Feb 12, 2008 | 10:26 PM
bubbas78f250
When I talked to Tim he told me I would be in the low 9's that is why I am trying to avoid 91 octane. This is a daily driver.
Old Feb 12, 2008 | 10:29 PM
hollenjoe's Avatar
hollenjoe
ok, but try it once just to be sure, and if its cured, use thicker head gaskets and try 87 again,
what about egr? could it be bad?
Old Feb 12, 2008 | 10:42 PM
bubbas78f250
No egr, I Am running the weiand intake. and other ifno on what i did be helpfull?
Old Feb 12, 2008 | 10:56 PM
hollenjoe's Avatar
hollenjoe
did you polich well your cumbustioon chambers? a dirty one could make your engine ping, you should´ve checked you chambers cc also, I dont know what else could be causing it, but the only solution would be trying a blend from 87 octane and 91 to see if it stops....
Old Feb 13, 2008 | 12:47 AM
fmc400's Avatar
fmc400
MSEE
What distributor are you running? If you are running the stock one then that is your problem - the stock distributor on a '78 will be set up for EGR. Engines with EGR are set up with a steeper timing curve to provide more advance at part-throttle. If you take the EGR away and leave the distributor untouched then you will get pinging. One way to fix this is to replace the standard vacuum advance with an adjustable vacuum advance; then you can adjust the timing curve with an allen wrench.
Old Feb 13, 2008 | 07:48 AM
bubbas78f250
The heads were cleaned well before I put them on but no porting done that I know of. It is a stock distributor. Whould switching to an msd help me?
Thanks
Bubba
Old Feb 13, 2008 | 07:41 PM
danlee's Avatar
danlee
You need to change the springs in the distributor to slow the mechanical advance, if you do not have EGR. The springs in the '71 distributor are the correct springs. Crane sells a kit with an adjustable vacuum advance and several different springs. You need stronger springs, you are getting full mechanical advance at too low RPM.
Old Feb 13, 2008 | 08:23 PM
bubbas78f250
I have been looking for the spring kit online with no luck so far. Can some one point me the right way?
Thanks
Bubba
Old Feb 13, 2008 | 08:46 PM
danlee's Avatar
danlee
The Crane kit is: Crane Cams 99607-1
It's available at Summit Racing (www.summitracing.com).
Here is a link to the instruction sheet.
http://static.summitracing.com/globa...s/crn-271e.pdf
Old Feb 13, 2008 | 10:26 PM
bubbas78f250
Thanks for all the help. I am going to try and get one of these kits so I can put it in this weekend. I post the results.
Thanks
Trent
Old Feb 18, 2008 | 12:40 PM
bubbas78f250
As a test I disconected the vacume line to the avance and plugged it. Went for a drive and all pinging was gone. Got the advance kit and installed it without using new springs. reset the timing and it runs great now.
Thanks for the help.
Bubba
