Parker Funnel web intake......?
Old Feb 12, 2008 | 07:06 PM
turret_plug's Avatar
turret_plug
Anyone know anything about these things? I have the opportunity to pick one up for 100 bucks, I just like the way it looks.... I like my eddy intake, but this thing looks angry
Old Feb 12, 2008 | 07:17 PM
85e150's Avatar
85e150
They say "Funnelweb with port match" for this motor:
https://www.ford-trucks.com/forums/6...8-hot-rod.html
Picture here, make sure it's good and grab it for $100.
http://parkerracing.com.au/funnelweb302.html
Old Feb 12, 2008 | 11:02 PM
turret_plug
ok, dude sent me a picture of the intake, I gotta' have it... I am just concerned about hooking up ,y throttle cable, vacuum lines, kickdown rod, you know, the extras.... got to have it though.
https://www.ford-trucks.com/user_gal...177349.520.390
Old Feb 13, 2008 | 12:40 AM
fordeverpower's Avatar
fordeverpower
most funnelweb intakes are ripoffs of terry parkers original creation. I believe they are cast in china. As for performace, its better than the vic jr if the combo is right. Its a freak piece!
Old Feb 13, 2008 | 10:51 AM
Conanski's Avatar
Conanski
They brag it flows 300cfm per runner. Considering a good running 302 only need about 600cfm total I predict this will make for really soggy power at everything but redline.
Old Feb 13, 2008 | 05:07 PM
85e150's Avatar
85e150
The 331 in HRM makes 230 horse, 336 lb/ft at 3600 rpm, so with the right OTHER parts, soggyness can be avoided. (waiting for flame regarding what it makes at 1400 rpm from the six forum regulars)
On an otherwise stock engine it's probably a bowser.
Old Feb 14, 2008 | 09:32 AM
Conanski's Avatar
Conanski
Interesting... but I wonder what the CR is on that motor...
Old Feb 14, 2008 | 03:16 PM
85e150's Avatar
85e150
12:1. They say they ran 91 octane unleaded with no detonation. This is a 4.125 x 3.1 motor, special heads, solids, forged pistons.
I see another mag (Mustang mag, 5.0/4.6, I can't recall) with a 533 hp 331 using the more common 4.030 x 3.25. Maybe I'll read it while my icecream melts next time I'm at the store....
Old Feb 14, 2008 | 04:16 PM
JBradley500's Avatar
JBradley500
i heard you can tell the difference between a knock off from china and the australian one by the icon on the intake. supposedly the one from australia has a kangaroo on it and the chinese one has a panda. this is just a rumor i heard from an engine builder, but it may be true.
Old Feb 14, 2008 | 06:33 PM
51dueller's Avatar
51dueller
Hopefully those figures are wrong as a 302 can do that with the right cam.
Now if you want a real intake...
http://www.canfieldheads.com/intake_manifolds.htm
Old Feb 14, 2008 | 07:06 PM
85e150's Avatar
85e150
From my other posting:
"336 lb-ft, 230 horse. At 3600 rpm.
407 lb-ft, 418 horse. At 5400 rpm.
387 lb-ft, 530 horse. At 7200 rpm.
It's 4.125 x 3.1, 331 cubes. "
The other mag's engine is a stock block, 10.4 :1, similar heads, diff manifold, 750 cfm carb as well, and also runs into the 7k zone.
Doubtless a 302 with the same stuff would make close to the same power, esp at lower revs.
Over 500 horse from a fits-anywhere 302 block. These are the good old days.
Old Feb 14, 2008 | 07:59 PM
51dueller's Avatar
51dueller
You have to remember you either build an engine for low end or high end and that engine is built for high end horsepower.
My 331 build which is tuned for low end will kick that engine's *** up to 4000 rpm and then the boss will be gone as it will just be hitting it's stride. The key to my setup is the custom designed camshaft tailored to my engine combination.
IMO a 7000 rpm engine is useless in a truck. Put that engine in a car and it's a whole different animal.
Old Feb 14, 2008 | 10:45 PM
85e150's Avatar
85e150
Ever dyno yours? 336 ft/lb at 3600....it can't be totally flat at 2600, but who knows? Maybe it wouldn't pull the dyno below 3600.
Old Feb 15, 2008 | 08:07 AM
Conanski's Avatar
Conanski
Detonation is not the concern here. It's a long way from 8.8:1 to 12:1, and if you dynoed 2 motors with identical specs except for the CR, the low compression motor would make much less TQ at lower rpms that the high compression motor. As it stands a stock 5.0 makes a peak of 290lb/ft TQ at 3600rpm with a tiny little stock intake, bolting on a monster volume intake will move that peak higher in rpms, not lower.
Old Feb 15, 2008 | 08:55 AM
51dueller's Avatar
51dueller
Well my engine isn't quite finished yet as it still needs a couple pieces but will by dynoed once the truck is operational. My peak torque will be at 3600 rpm and peak HP at 4900 RPM. It'll make about 380 ft-lbs at 3600 rpm and 325 hp at 4900 rpm. These aren't Desktop Dyno numbers either as it says it will make much more but I doubt it.
mikey1968
Jun 28, 2016 02:14 PM
korze
Apr 18, 2016 10:40 PM
BigCountry1978
Jan 4, 2016 09:37 PM
bloodspoint
Sep 29, 2010 04:22 PM
5.0stang
Sep 21, 2007 08:52 AM
