.....And a poperly-geared 250 HP gas motor will generate the same amount of rear-wheel torque as a properly-geared 250 HP diesel.
...You had me until there...
There's no way my grandpa's little 3.0 that pumps out 200 horsepower is going to outpull my 351 that has the same horses, everything else being equal, like your saying.
Same thing with a diesel. Diesels aren't like a gasser....whenever the horsepower goes up, so does the torque. A 7.3 makes it's horsepower AND torque peak at just about the same RPM, unlike a gasser, where when the horsepower rises, the torque drops.
To me it's like your saying you can take a little 4 cylinder honda pushing 250 horsepower, THEN dropping it in a superduty and expecting it to pull the same load as a 7.3 making the same horsepower, everything else being equal...impossible to say the least. Your gonna need torque....
At the HP peak, and with the right gearing, yes, they are generating the same torque-to-the-ground.
However, the torque curves are much different, and the amount of low-end torque is WAY different.
HP ratings are at the peak HP - it has nothing to do with how well the engine will pull a load all over the RPM range.
I've had this discussion with Hemi owners (in-laws) comparing their 5.7 to my V10. And then I show them how I can pull 2ft diameter trees through the woods at 1200RPM. They wouldn't try it though, their IFS front-end would have been dragging on the ground
They don't get it. Even though their HP rating is higher than my 2-valve V10, I can do much more actual work at a lower RPM. Because my V10 puts out 80% of it's peak torque at 1000RPM.
I've always had this idea for a way to measure torque across the board - figure the area under the curve from 1000 RPM to the HP peak RPM.
Say you have two guys lifting 50 pound sacks of feed into a truck. They both have the same torque rating.
One guy does 2 sacks a minute, the other does 4 sacks a minute. The second guy has twice the horsepower as the first guy.
So, loads and gearing being equal, the higher horsepower will win the race.
However, this is not a race and these are not muscle cars. Raw torque will pull your load. Remember, some of the semis of the past only had 180 horsepower, yet they pulled 80,000 pound combos up and down the road. They may not have gone up the hills fast, but they got the job done.
[QUOTE=Truckin4life]alright just what ihave read, there are some VERY misinformed people here. Horespower, does NOT alway win. Any REAL gear head knows, that torque is what gets the wheels moving. If gassers pulled just as good as a diesel, then why would EVERY semi i have EVER seen be DIESEL powered, wouldnt it just make since to power it with gas and just get rid of diesel all together.
QUOTE]
wish I was young enough to say that,I can remember when very few were diesel
Remember, the original post was about a 5.4 pulling a load up a short steep hill under a narrow set of conditions. Not doing that every day, all day long. Please don't think that I have lost sight of the fact that there are major differences between these engines.
The guy was asking about 7.3's and I wanted to make it clear that a stock 7.3, while pretty good, is not the solution to every towing problem.
I totally agree with you, the 7.3 is not the solution for every towing problem. But I think it would be the solution to his towing problem.
something was going on with your trucks engine or transmission, even a stock 5.4 should have NEVER had a problem towing an empty trailer! It's comparing apples to oranges comparing the 5.4 and 7.3 when it comes to towing
Yeah, thanks.
It's a poor frog that'll croak for its own pond...
I have never owned a 7.3. I have however owned a 5.4 and currently own a 6.0 PSD.
The 5.4 was the 2 valve version as is yours. It was in an extended cab long box 4x4 with XLT and FX4 options, and just about every other option available. I never weighed it but it was heavy.
That truck routinely pulled a 7000 lb 26 ft. trailer while carrying three adults, a full bed of firewood with generator, and supplies in the trailer for two weeks, up and down and through the Adirondack mountains in NY and I never had a power problem.
I won't get into the gas vs diesel or Hp vs torque debate. There are no winners in that argument.
I loved my 5.4 and love my 6.0. Have not towed with the 6.0 yet.
I'm not that old, but I have read enough articles that there were gas powered big trucks. heck I have seen them. There is a mid 60's GMC tandem axle truck (guessing on year) powered by an inline 6 gas sitting in the woods not far from home. And I also was reading about MACK trucks using gasoline engines as well.
