Warn Manual Hubs
Old Feb 12, 2008 | 03:00 PM
  #31
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Scott, I got my parts in for my auto hub maint. I will be doing that this weekend. Looks easy enough. I'm not having trouble but that sounds like something good to do.
Old Feb 12, 2008 | 03:06 PM
  #32
sflem849's Avatar
sflem849
Let me know how it goes. Maybe when the chopper box moves out I will do it.
Old Feb 12, 2008 | 03:09 PM
  #33
miller_feed
Originally Posted by zx250
IIRC there are only two wires on the vacuum solenoid. Switch the hot one with wires run to the cab and a switch. Turn off to break the circuit and the solenoid will remain closed and vacuum pump will work as if nothing is wrong. Switch on to allow the circuit to make and when the ESOF switch is made the solenoid will make and your hubs will ingage.
I have to use the ESOF switch to turn the transfer case to low. I don't quite understand this yet. The solenoid turns the vacuum off to the hubs? And if I join the hot wire to a toggle switch then back to the solenoid hot post, the hubs will not lock?
Old Feb 12, 2008 | 03:51 PM
  #34
zx250's Avatar
zx250
Of the next Riffraff East
The ESOF switch energizes the motor on the transfer case to engage the front drive shaft and also enegizes the solenoid to open the vacuum lines to the front hubs. If you switch the solenoid power supply, the transfer case motor will still work and the solenoid will not if you have it switched off. The vacuum pump comes on when the key is turned and anytime more vacuum is needed. It has nothing to do with the ESOF switch.
Old Feb 12, 2008 | 03:54 PM
  #35
miller_feed
I got it now. Thanks for that info, I will be looking at doing this this weekend.
Reps to you Barry.
Old Feb 12, 2008 | 03:57 PM
  #36
miller_feed
Should be easy enough. I will post back when I get it done.
Old Feb 12, 2008 | 04:01 PM
  #37
zx250's Avatar
zx250
Reps to you Barry.
Thanks, and let us know how it goes. We may sure enough have a "Miller Mod" on the way.
Old Feb 12, 2008 | 04:08 PM
  #38
miller_feed
lol, Barry, you had more to do with this than I did. But I will sure trie it and let you know.
Old Feb 12, 2008 | 06:06 PM
  #39
greagin's Avatar
greagin
The Miller Mod sounds cool for those that simply do not want to give up their auto locking hubs, but boy i sure love my Warn Premium Manuals!! $170 out the door and 15 minutes to install and never ever have to worry about auto locker hub maint or breakage ever again!! priceless.....
Old Feb 12, 2008 | 06:13 PM
  #40
zx250's Avatar
zx250
Yep, even looks good on dirty wheels.
Old Feb 12, 2008 | 06:17 PM
  #41
greagin's Avatar
greagin
Not to hijack the thread, but how do you post pics like that?? and you are right Barry, it's a beautiful thing!!
Old Feb 12, 2008 | 06:24 PM
  #42
zx250's Avatar
zx250
When you click post reply you should see in the bottom left corner
<FIELDSET class=fieldset><LEGEND>Miscellaneous Options</LEGEND><LABEL for=cb_signature><INPUT id=cb_signature tabIndex=1 type=checkbox CHECKED value=1 name=signature>Show your signature</LABEL>
<LABEL for=cb_parseurl><INPUT id=cb_parseurl tabIndex=1 type=checkbox CHECKED value=1 name=parseurl>Automatically parse links in text</LABEL>
<LABEL for=cb_disablesmilies><INPUT id=cb_disablesmilies tabIndex=1 type=checkbox value=1 name=disablesmilies>Disable smilies in text</LABEL>
</FIELDSET> <FIELDSET class=fieldset><LEGEND>Attach Files</LEGEND>Valid file extensions: gif jpe jpeg jpg pdf png psd
******** type=text/javascript><!--document.write('<input type="button" class="button" tabindex="1" style="font-weight:normal" value="Manage Attachments" title="Click here to add or edit files attached to this message" onclick="manageattachments(\'newattachment.php?t=7 06968&poststarttime=1202862057&posthash=d88dd75fb9 970bb169669eee66ba356f\', 480, 480, \'5726323\')" />');//-->*********><INPUT class=button title="Click here to add or edit files attached to this message" style="FONT-WEIGHT: normal" onclick="manageattachments('newattachment.php?t=70 6968&poststarttime=1202862057&posthash=d88dd75fb99 70bb169669eee66ba356f', 480, 480, '5726323')" tabIndex=1 type=button value="Manage Attachments">
</FIELDSET>
Just click on the Manage Attachments button and follow the instructions. I upload directly from my computer. Please downsize your pics to somewhere around 600 x 700 pixels so it don't take up so much room on the thread.
The other way is to upload the photo into you gallery, then you can just copy and paste from you gallery.
Old Feb 12, 2008 | 06:48 PM
  #43
greagin's Avatar
greagin
10-4, thanks!!
Old Feb 12, 2008 | 06:55 PM
  #44
greagin's Avatar
greagin
This is a test pic, it's my old truck before i got my 2001
Old Feb 12, 2008 | 07:06 PM
  #45
zx250's Avatar
zx250
Looks like you got it!
