Great concept, but bad design. If I start to have a problem, I might switch to manual hubs. But untill then I will keep what I have. I don't go in bad stuff anyway. If I get stuck it is usally in a pasture.
thats me. I just want a functional truck to pull my camper and trailer if I want tohaul a junk car or two.
The cool thing about manual hubs and hauling a load is you can flip your switch to 4wheel low with you hubs unlocked and you will have a granny gear for backing a heavy load in a tight spot.
I could put an inline valve to stop vacuum going to the hubs. But your right about the low gear without locking the hubs, while on cement. I don't think it would be a problem on dirt.
I would think that the heat generated by just driving and braking would thaw it out enough to turn if you are thinking ice in the hubs.
Like I told you guys, Dad turned them some time in December. The frickin things couldnt be rusted solid in a month and a half so it must be ice. I have felt them when I get home and they are not warm to the touch. They do feel like they want to turn different amounts every time.
Pull up beside another trucks exhaust, diesel if possible and let the exhaust blow on the hubs for a few minutes. If they don't turn then, well, they stuck, not froze.
Oh yeah, one thing we have around here is cows. Helped on a dairy farm when I was younger and didn't know there were much easier ways to make a living.
Stops the jumping and hopping on dry dirt when you have the wheels on full lock trying to get a big camper in a little site, with a wife that't not the best on backing instructions.
I could put a switch on the vacuum pump power supply inside the cab and turn the power off to the pump. Not often I need 4x4 backing my trailers. Hummm
Man that would be simple to do. Even if the heater goes to the defrost for a little while, that wouldn't hurt anything. Is there anything important that the vacuum operates? SORRY.
I like that To think I was just going to put the turbo heater on them...we used to throw foam board on each side of the spreader and then shove the heater in the new "heat tunnel" It would work like a champ...usually. Now we have a Knight slinger. Now worries there!
Darn, I wish I knew more about how to do all this. I am from the oil field, if you can't use a hammer on it, throw it away. lol
IIRC there are only two wires on the vacuum solenoid. Switch the hot one with wires run to the cab and a switch. Turn off to break the circuit and the solenoid will remain closed and vacuum pump will work as if nothing is wrong. Switch on to allow the circuit to make and when the ESOF switch is made the solenoid will make and your hubs will ingage.
