Fuel return pressure
Old Feb 11, 2008 | 08:39 PM
kawa's Avatar
kawa
A few days back someone asked if anyone knew the fressure of the fuel return line. There does not appear to be much pressure but it can sure puke the fuel out when the line is not connected.
Please don't ask me how I know.
Rog
Old Feb 11, 2008 | 08:46 PM
WALJON's Avatar
WALJON
Oh yeah lol sounds like you had an experience today
by the way that was me asking that question
Walter
Old Feb 11, 2008 | 08:47 PM
tjbeggs's Avatar
tjbeggs
Well how do you know?????
oh yeah. Thanks for the info too!! I will tell my bad story of the day if you tell yours!
Old Feb 11, 2008 | 09:04 PM
MADVAN's Avatar
MADVAN
How does winter ULSD taste?
Same as non winterized?
Mountain dew look but not the taste!
Tj
I hear your's envolved a sawzall.
Bill
Old Feb 11, 2008 | 09:06 PM
kawa's Avatar
kawa
OK, Yeaterday I installed my fuel filter with the updated heater. one (1) hour later I am puking fuel out the bottom. I pull the filter and find that the water sensor is cracked. replaced that reinstalled the filter. Start the truck, fiddle with the radio, hear fluid running. Shut off truck and notice fuel return line not connected. It can really puke fuel but luckily it doesn't spray it on the fire wall. Changing the thermostat went well.
OK TJ, how was your day??
Rog
Old Feb 11, 2008 | 09:07 PM
WALJON's Avatar
WALJON
Tj
Bill
LOL I hear ULSD puts lead in your pencil
Old Feb 11, 2008 | 09:16 PM
tjbeggs's Avatar
tjbeggs
Well I guess its a good thing fuel is cheap now a days!! ouch!
Ok so my story starts like this. Got a new Dp-tuner chip to try out (only testing don't get to keep it) and its really small with no switch. Get my chip out and plugged in the new chip. No WTS light. bad conenctions. try it again same thing. So as I am removing it the second time I DROPPED IT INTO THE PCM!!!! So now working outside (20 degree's or so) I have to pull the PCM out. I was at Rick's shop and it ended up taking up about an hour of messing around and getting fingers warm to get the PCM out since the inner fender is in the way. Got the chip out cleaned the contacts really well then put everything back together. I was close to just cutting a whole with the mini sawzall in the inner fender. I was not very happy that a 10 minute deal took an hour. Plus Rick had stuff to work on that would actually make him money!!
But my truck is testing a new tune from Jody but most of all for me is that my loping idle is gone and the truck idle smooth a silk with the 10k mod gone. Aside from that I am not real crazy about the tune but I am only testing one very small part of it.
Old Feb 11, 2008 | 09:28 PM
kawa's Avatar
kawa
That's it? Cold fingers??? Jeezch Louise I thought you really had a tale of woe, whoa? what ever. Betcha can really get that PC in and out really fast now, huh??
Rog
Old Feb 11, 2008 | 09:41 PM
WALJON's Avatar
WALJON
So was it the 10k mod tim that was giving the loping Idle? or something in the new tune that corrected it
just curios
Walter
Old Feb 12, 2008 | 07:23 AM
tjbeggs's Avatar
tjbeggs
Rog that hurts!! I don't do well when my fat fingers get cold!! I'm a sissy when it comes to working on vehicle outside!! I am spoiled!!
Waljon my start up lope idle was caused by running the split shot injectors on single shot programming. I had the chip burned for splits shot injector and it doesn't lope now. The 10K mod helped the loping to not be as bad at startup. But that was just a bonus for the testing.
Old Feb 12, 2008 | 08:30 AM
Action4478's Avatar
Action4478
Rog
It was my fault he was outside,, I didn't think it a good Idea to start the truck with the chip laying inside the PCM ...It ended up taking three of us ,, but ,,,,
In the end.....
PCM ...(0)...Us
(1)....
Old Feb 12, 2008 | 08:45 AM
tjbeggs's Avatar
tjbeggs
Yeah we won but it wasn't a clean victory! And no the PCM will be just as difficult next time other than I know the tricks now!!
Old Feb 12, 2008 | 06:30 PM
WALJON's Avatar
WALJON
Oh I see
thanks
Walter
Old Feb 12, 2008 | 09:08 PM
Neal 97 250's Avatar
Neal 97 250
My fingers still cary scars from that inner fender. Booger aint it?
Old Feb 12, 2008 | 09:09 PM
tjbeggs's Avatar
tjbeggs
Yes that inner fender was taken care of with a finely tuned 2 foot long screw driver and a skilled worker on the handle!!
