Gauges
Old Feb 11, 2008 | 07:49 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Gauges
I just got my gauges in this weekend and was wondering what normal boost is on a stock 01? Wot I can hit 16 psi. Is this too low or normal? I had cleaned up all of the intake and intercooler boots a couple of weeks ago.
Old Feb 11, 2008 | 07:52 PM
aocabrown's Avatar
aocabrown
Pull the red wire off the wastegate actuator (just behind turbo) and secure the wire on the intake clamp bolt nearby. Re-test...I bet you see 20.
Old Feb 11, 2008 | 07:53 PM
jhand124's Avatar
jhand124
That's about right with the waste gate connected.
Old Feb 11, 2008 | 09:47 PM
Izzy351's Avatar
Izzy351
Yup -- sounds about right, but a hair on the low side. I think a lot of folks see 17-18 stock, IIRC.
Old Feb 11, 2008 | 09:51 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Thats perfectly normal.
Old Feb 11, 2008 | 09:54 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I saw 20 with the red wire off going WOT up a hill but only saw 17 at WOT going up the same hill with the red wire on
Old Feb 11, 2008 | 09:57 PM
Stroker 94 1/2
Thanks guys!! I'll try it without the red line hooked up and see what I get?
Old Feb 12, 2008 | 01:26 PM
Stroker 94 1/2
I just got done doing a run with the red wire off and I got 21 psi. I guess everything is good. I also ordered my 4" exhaust this morning and should have it on this weekend!!!
I also tried to order my DP this morning but wouldn't ya know it there closed today. I guess I'll try again Wednesday. Thanks for the help fellas!!!
Old Feb 12, 2008 | 02:55 PM
Izzy351's Avatar
Izzy351
You're in good shape then -- be careful with that red line off when you get the DP in. I was hitting 27-28psi, but it was surging terribly. I put the WW in which took care of it, but I still run with the red line off and get about 25-27psi.
Old Feb 12, 2008 | 03:57 PM
SteveKran's Avatar
SteveKran
According to my Quadzilla Commander I'm running at 22psi WOT and then it throws a code (I get a light on my dash). I'm guessing that's the overboost code. If I had the boost fooler, how high would my boost actually go, AND would the truck go faster?
Old Feb 12, 2008 | 04:04 PM
Izzy351's Avatar
Izzy351
I'm assuming the Quadzilla reads the boost from the PCM (MAP Sensor). If that's the case, then you won't see anything above what the boost fooler lets past it. I have the ITP Overboost Annihilator and regulates the boost to about 21 psi. The biggest problem with that is you won't see the real boost numbers when you need to the most -- when they get at or above 25 psi. BTW, once the PCM sees 25, the PCM will defuel the engine. IMHO, the electronic readers are cool to look at, but I prefer analog gauges. If you have an analog boost gauge, you connect it before the boost fooler so it sees the real deal.
Old Feb 12, 2008 | 04:18 PM
SteveKran's Avatar
SteveKran
Is there any way to change how the Quadzilla reads the boost to after the boost fooler? I'd like to keep my cab looking clean without all the analog gauges everywhere. The one digital gauge really looks slick.
What kind of output is the map sensor putting out that the Quadzilla is reading and interpreting into pressure? Is it voltage, current...? If it's one of them I think I could rig something like a Rosemount pressure transmitter to read the pressure and output either a voltage or mA signal.
Has anyone ever messed with anything like this before?
Old Feb 12, 2008 | 04:21 PM
Izzy351's Avatar
Izzy351
I have no idea. You might call them directly. Maybe the make a module for the QZ to read from just for boost. Seems like kind of a long shot, honestly. If you only need one gauge, you can mount it on the steering column and it won't be that obtrusive. I've also seen mounts the put gauges in the top left and/or right of the stock cluster. Kind of hard to visualize, but I've seen them and they actually look pretty cool that way.
Old Feb 12, 2008 | 04:25 PM
SteveKran's Avatar
SteveKran
Yeah, it might be a bit of a long shot. I think I might go with 3 gauges under the dash because I will be adding train horns in the near future and would like to know what kind of pressure is inside my air tank. I'm not sure what the 3rd gauge would read though.....maybe voltage? I had my alternator die on me the other day and it really would have been helpful to know what kind of voltage I was running BEFORE it completely died.
Old Feb 12, 2008 | 04:30 PM
Izzy351's Avatar
Izzy351
I agree -- my alt died last June, and it would've been nice to see it coming. It actually started acting up again last week, too. I noticed the battery light flash on & off a couple times. I'd really like to add water temp & oil temp as well. That's over and above the HPOP gauge & fuel pressure that I already have in the works...
