brakes lock
Old Feb 11, 2008 | 07:45 PM
dugoodm's Avatar
dugoodm
6th Gear
brakes lock
I have a 1981 F100 that has an issue with the brakes locking. I've replaced shoes, pads, wheel and master cylinder without resolving the issue. Once you get the truck moving it does OK. After sitting for a bit and restarting, the rear brakes will be frozen.
What have I missed???
Thanks,
Duane
Old Feb 11, 2008 | 08:17 PM
muddog80's Avatar
muddog80
two things you can ck is the wheel cylinders or might just need to adjust your brakes
Old Feb 11, 2008 | 08:20 PM
ctubutis's Avatar
ctubutis
Prolly the parking brake cables, which have a history of rusting & corroding into one, solid mass. Search this forum or wait for Dave (Franklin2) he's offered some good suggestions on how to deal with it, some not too awful long ago.
-ct
Old Feb 11, 2008 | 09:51 PM
dugoodm's Avatar
dugoodm
6th Gear
Wheel cylinders have been replaced and brakes adjusted when new shoes were installed.
Old Feb 11, 2008 | 09:54 PM
dugoodm's Avatar
dugoodm
6th Gear
-ct
Thanks for the info. I was wondering about the parking brake cables, but wasn't sure if they would cause this to happen. I'll have to search this forum (once I learn how). This is my 1st time on here to post a message.
I appreciate your input.
Old Feb 11, 2008 | 10:00 PM
muddog80's Avatar
muddog80
your brake lines may still have air in them or even maybe clogged up might try undoing the lines from the master cylinder and blowing them out and ck your park break cable
Old Feb 11, 2008 | 10:01 PM
ctubutis's Avatar
ctubutis
The Advanced Search is pretty cool, you can use all kinds of criteria. The Search link is offered on the forum's front page, upper RH corner.
-chris
Old Feb 11, 2008 | 10:17 PM
Franklin2's Avatar
Franklin2
Yes, it does sound like the parking brake cables are stuck. As you drive it, the rear brake drums get hot and expand, and relieve some of the pressure. When you stop, they cool off and lock up the brakes again.
Old Feb 12, 2008 | 06:55 AM
dugoodm's Avatar
dugoodm
6th Gear
Thanks Dave. I'll see what I can find for cables for this vehicle.
Duane
Old Feb 12, 2008 | 09:06 AM
Franklin2's Avatar
Franklin2
If you want to be 100% sure that's the problem, when it cools off, jack the rear wheels up and see how hard they are to turn.
