1978 - 1996 Big Bronco
351m?
Old Feb 11, 2008 | 04:49 PM
FrdKng94's Avatar
FrdKng94
Question 351m?
Ok guys.. I'm totally in love with 78/79 Bronco's. I've been looking to buy one for quite some time now and can only find one's that have the 351M. I've been told by some friends and bronco owners that the 351M is a gas-guzzling dog with no power at all. Is this true? Is a 78/79 with the 351M even worth my time or money?
Old Feb 11, 2008 | 06:07 PM
dragogt's Avatar
dragogt
the 351M has good potential, or you can swap 460 in it's place. https://www.ford-trucks.com/article/...erformanhttp:/
http://www.fordmuscle.com/archives/2007/02/Ford400/index.php
Old Feb 11, 2008 | 06:58 PM
Bimmerboy1989's Avatar
Bimmerboy1989
the 351M is a low compression 351C I believe. I've heard it's a dog. I know of two broncos of around that year and both of them have a 460 swapped into them. The 460 is the way to go.
Old Feb 11, 2008 | 07:07 PM
dragogt's Avatar
dragogt
the biggest problem w/ the 351m is all the emissions crap it got stuck with. get rid of that crap, install a good timing set stright up, and they can make some decent power. http://home.earthlink.net/~bubbaf250/index.html
Old Feb 13, 2008 | 12:40 PM
bmc69's Avatar
bmc69
Turn the 351m back in to a 400, install a decent cam, 4V intake and 600 cfm carb and you'll be amazed how it performs compared to the stock 351m. If it is due for a rebuild anyway, the 400 'conversion' costs nothing extra.
Old Feb 13, 2008 | 05:12 PM
MBBFord's Avatar
MBBFord
The 351M isn't the same as a 351C, not even close.
TO actually 'turn the 351M back into a 400' you will need to put 400 crank and rods.
While in there, it'd be worth putting some new pistons and boring out the cylinder walls. With a straight up double roller timing chain, 600ish CFM carb, intake, rv cam, headers and you will have a very powerful 400. It will put a stock 460 to shame.
The 351Ms and 400s came out right when a bunch of emission standards were put in place, and basically turned them into dogs.... Retarded timing, decreased compression, catalitic convertors, egr, ect...
Old Feb 14, 2008 | 12:12 PM
bmc69's Avatar
bmc69
I'm sure you meant 'crank and pistons'...rods are the same. Which is why changing a 351m back to a 400 in the course of a rebuild is practically a 'no cost' upgrade, since the pistons get replaced anyway and the cost of a 400 crank kit is little more than the cost of having the 351 crank ground.
Old Feb 14, 2008 | 02:40 PM
codyingersoll123's Avatar
codyingersoll123
exactly...I would buy it...I just bought a 79 F150 with a 351M motor in it...its completely stock and it has *****. I feel it has more power then the 302 I have in my 95. And yes all you have to do is swap crank and pistons and bam you have a 400. I wouldnt over look the M motors just because they were laiden with factory restrictive devices...mine has all the emissions crap stripped off it and it runs like a top. couldnt be happier. If you can start with a 400 as then you dont have to swap the crank and pistons.
skibber
WTB - Ford Trucks & other vehicles
Dec 22, 2016 08:58 AM
351coupe
Ford Truck Parts for Sale
282
Feb 11, 2016 07:01 AM
rbpmdfacs
Sep 17, 2015 08:09 PM
82_F100_300Six
May 14, 2011 06:41 PM
Mil1ion
Alberta Chapter
Nov 22, 2004 08:36 PM
