View Poll Results: What's your MAX boost?
< 25 psi
27
14.44%
25-27 psi
50
26.74%
28-30 psi
73
39.04%
31-35 psi
29
15.51%
> 35 psi
4.28%
Voters: 187. You may not vote on this poll
Old 02-11-2008, 11:46 AM
OZX1's Avatar
OZX1
OZX1 is offline
I'm experiencing what I fear is too much boost, regardless of tuned or stock. I may have cracked or leaking CAC hoses, but that's just a guess. Let's see what kind of boost y'all are getting.
Old 02-11-2008, 11:55 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
I don't see much over 30psi.
Old 02-11-2008, 12:16 PM
EZ-Ford's Avatar
EZ-Ford
EZ-Ford is offline
Only have the stock guage, so hard to tell for sure. Max I have seen seems to be about 25, maybe slightly less.
Old 02-11-2008, 01:00 PM
brmpipes's Avatar
brmpipes
brmpipes is offline
About 29psi stock or 34psi tuned.trying to stay under 30psi if possible.i have aftermarket boost guage that is plumbed into power elbow.Should be fairly accurate.
Old 02-11-2008, 01:33 PM
tex25025's Avatar
tex25025
tex25025 is offline
I don't see much over 29(a few times I hit 31, but that has been few and that was with the Bully dog as well) with Matt's Hybrid Race.
Old 02-11-2008, 01:43 PM
3000 FPS's Avatar
3000 FPS
3000 FPS is offline
do not have any tuners and never goes over 28 PSI. I do have a after market gauge coming from the elbow.
Old 02-11-2008, 01:44 PM
OZX1's Avatar
OZX1
OZX1 is offline
To the point, I'm maxing 33 psi with the Gen-Econ tune from Matt, 35 psi with Hybrid Race and 30 psi stock...
These readings are on my Quadzilla Commander (OBD? ...tapped from the MAP). Do any of you use an OBD type gauge or a Commander for you boost readings?
Old 02-11-2008, 01:58 PM
4x4Mark's Avatar
4x4Mark
4x4Mark is offline
When I first installed my gauges, I tapped into the MAP line. Anything over 20psi got very erratic, so I took the advice of others and tapped into the elbow. I now have a nice, smooth reading no matter what PSI. Normally, just around 25 psi or a little higher - I don't push it hard for long.
Mark
Old 02-11-2008, 02:12 PM
OZX1's Avatar
OZX1
OZX1 is offline
Mark
The Commander has no analog (or mechanical) input for anything. I would like to use the actual readings from the elbow, but would need a sender to convert from analog psi to the electrical input needed by the Commander. Is there such a beast? Storm, anyone with a digital gauge set? How do you read on your truck? Do you depend on the LiveWire or Commander, or do you have an analog for boost?
Old 02-11-2008, 02:31 PM
jmaskew's Avatar
jmaskew
jmaskew is offline
I've hit 28-29psi for a few seconds on several occasions. Will this cause damage or am I ok? I have a Isspro 40psi gauge with the sender in the elbow.
Old 02-11-2008, 02:38 PM
Storm's Avatar
Storm
Storm is offline
I'm not aware of an electrical boost sensor that would work on the Commander. There are electrical sensors however.. Dunno..
I have gauges.. Not fond of the "computer" gauges..
Old 02-11-2008, 02:57 PM
tex25025's Avatar
tex25025
tex25025 is offline
I used to use the outlook when I had an all bullydog setup, but I will still reading below 30 for the vast majority of times and I ony hit 31 once and I was never able to duplicate it again with the triple dog. I had thought that the commander came with probes for the tranny and egt sensors and you could also have gotten it with the fuel sensor probe as well? To my knowledge other then those three sensors that I believed were for the commander, you don't usually have external sensors for digital gauges they derive all their info from the OBD-II port with the exception of the EGT gauge, that is the ony one that they have an external link for because the factory doesn't put a sensor for it and it is an important sensor to have.
Old 02-11-2008, 03:03 PM
OZX1's Avatar
OZX1
OZX1 is offline
I really have to get in there to clean. check and tighten all of the CAC tubes...
Old 02-11-2008, 03:09 PM
Storm's Avatar
Storm
Storm is offline
If you have the aluminum tubes make sure they are 9lb/ft torqued..
Old 02-11-2008, 03:10 PM
OZX1's Avatar
OZX1
OZX1 is offline
Originally Posted by tex25025
...I had thought that the commander came with probes for the tranny and egt sensors...
Roger that... I have the EGT probe and the trans sensor installed, and they are working very well. everything is acquired by wire-tapping into existing sensor leads. My real concern is that the boost readings inferred by the MAP sensor line tap is not the actual amount of boost. The readings are not erratic in any way, they just spike kinda' high at times. 35 psi on Hybrid Race with my foot in it for 3 seconds got me on the alert!
Quick Reply: What's your MAX boost?
