Hard to accelerate.
Old Feb 11, 2008 | 10:41 AM
hankp's Avatar
hankp
Hard to accelerate.
2003 Eddie Bauer Expedition 5.4. Sputters when trying to accelerate slowly. Especially when hitting incline while using cruise control. No error codes that I can find. I don't know where to start. Replaced the fuel filter which did not help.
Old Feb 11, 2008 | 05:07 PM
wilkinda's Avatar
wilkinda
i had the same exact issue with no codes as well. It ended up being a coil over pack that was bad. I since I have had other Expeditions I know they don't just go bad one at a time, they usually start going bad with weeks or months so i replaced all eight COPs and spark plugs... PROBLEM SOLVED!!! gas mileage is coming back to normal as well
Old Jul 13, 2008 | 05:48 PM
charonica's Avatar
charonica
Unfortunately I had the same issue. change plugs , not coils did an oil change, change the air filter. No luck. I had to change the catalyct converter problem solved I will also change the filter.
charonica's Avatar
charonica
By the way does anyone know were the pcv valve is located.
