V6 Cam sync question
Old Feb 10, 2008 | 10:14 PM
flagbagger's Avatar
flagbagger
4.2 V6 syncronizer
Originally Posted by BrianA
The 4.2 is a conventional pushrod motor - no overhead cam(s).
It does use a cam chain, not a belt.
No routine maintenance is required.
Just have to replace it if it breaks. I have no recollection of ever hearing of one breaking.
Not sure if this is the right way to go about this but have a question WRT V6 cam/timing/syncronizer.. just in the process of rebuilding 4.2 that wasted #1 & 4 pistons with hydrolock. Question: as I removed the timing /front cover but did not remove the Cam syncronizer, is it still necessary to reset the cam timing for correct fuel delivery (#1 cylinder at TDC on compression stroke)??
Thanks for any/all advice
Cheers
Flagbagger
Old Feb 11, 2008 | 08:54 AM
BrianA's Avatar
BrianA
Hi - Welcome to FTE! Glad to have you join us.
I split your post into a new thread so maybe it would get noticed more easily.
You ask a good question and sorry to say, I don't know the answer. I'd guess not, but don't know for sure.
Maybe somebody else will know.
Best of luck on completing your rebuild and again, nice to have you here at FTE!
Old Feb 14, 2008 | 05:28 PM
flagbagger's Avatar
flagbagger
Cam Sync 97 4.2L
Obviously, not too many folks involved in timing 4.2s.
Anyway, I borrowed the alignment tool from a local engine rebuilder (who had done some cleaning & polishing of block, crank & cam bearings..etc) & checked my syncronizer. It was positioned correctly but I'm still not sure if that was just good luck or whether it doesn't move if you don't remove it from the timing cover. My personal feel is that with two gears meshing, the chance of it being meshed in the wrong cog would be extremely high.
Anyway, now I know for sure & should avoid any SFI problem (from this source anyway) on startup.
cheers
Old Feb 14, 2008 | 07:46 PM
BrianA's Avatar
BrianA
Thanks very much for the update.
Posting follow-ups, resolutions, etc. is always appreciated and might be just the info another guy needs one day.
Best of luck and thanks again!
fordkev
Engine Swaps
18
Apr 14, 2023 02:08 PM
carlsson
Mar 23, 2010 10:27 PM
firerescuejason
1997 - 2003 F150
Dec 31, 2007 01:12 PM
grumpy1
Apr 2, 2005 10:27 PM
87rustbucket
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 11, 2004 08:27 AM
