Front Axle Bearings
Old Feb 24, 2008 | 11:33 AM
tbirdage's Avatar
tbirdage
I had a noise recently in my front right and could not, for the life of me, figure it out for the longest time. The noise I had sounded like I was driving on a metal bridge or over a rumble strip, kinda/sorta. It would quit as soon as I'd switch on the 4X4, I could switch it back off, hit a bump, and it would start doing it again. It ended up being the needle bearing inside the "sealed" hub assembly. I replaced both sides for $11 each from NAPA. I suggest to everybody to pop these out and grease them at least every 60-70K. Axle shafts are expensive to replace and I happened to get lucky and not tear one up. Hope this helps, good luck
Old Feb 24, 2008 | 01:54 PM
pctjk's Avatar
pctjk
Stu....do you have the part numbers for the NAPA parts and what year is your truck.
Thanks
Jeff
Old Feb 24, 2008 | 02:02 PM
tbirdage's Avatar
tbirdage
Thanks
Jeff
B2110. My truck is an '02
Old Feb 24, 2008 | 02:05 PM
tbirdage's Avatar
tbirdage
Originally Posted by RobertJohn
No special tools needed...I've changed mine and I'm no mechanic.
The seal I had pushed on using a pipe and flange, theres a post somewhere telling about this...Good luck and if I can do it anyone can..
http://seven.three.superdutypsd.com/...axle_seal_tool
Eric Schott
Apr 7, 2014 08:22 PM
jvaski
1997 - 2003 F150
17
Dec 28, 2010 07:30 PM
jvaski
1997 - 2003 F150
21
Mar 25, 2007 11:09 AM
ironmine
Nov 16, 2005 08:51 AM
