Gauge Problem
Old Feb 10, 2008 | 11:09 PM
jhimmelsbach's Avatar
jhimmelsbach
Gauge Problem
I'm having problems with fuse #17 that feeds the gauges, and other items. When ever I move the gear shift lever out of drive, it blows the fuse. I realize that something is grounding out, but without pulling the column apart I'm lost. I can not see any wires that are rubbing from the under side. This is for a 1997 F250 HD CC, w/7.3
1997 F250, XLT, 4WD, Auto, 3.73 LS, CC, 3.5 down pipe, no cat, 4-inch exhaust
Old Feb 10, 2008 | 11:36 PM
Surge08's Avatar
Surge08
does it have O/D?
Old Feb 11, 2008 | 12:17 AM
jhimmelsbach
Yes, it has overdrive on the shift lever.
Old Feb 11, 2008 | 08:12 AM
Franklin2's Avatar
Franklin2
I may totally out in left field here, since I only have a 99 diagram, but fuse #17 in the underhood fuse box goes to the transfer case shift circuit. If that's not it, sorry, that's the only diagram I have that's close to yours.
Old Feb 11, 2008 | 09:20 AM
jhimmelsbach
My fuse #17 is inside the cab. I'm just not looking forward to dropping the column.
