E4od question!
Old Feb 12, 2008 | 09:27 PM
jr32560's Avatar
jr32560
I've done smaller trans with just a floor jack or 2 people-the e4od is a beast use everything you got handy to support it-they weigh a ton!well maybe a pound or two less
Old Feb 12, 2008 | 09:32 PM
kuzycc's Avatar
kuzycc
I found that e4od really easy to ballance on just a floor jack, yeah, it was heavy but much easier to ballance than a standard.
Old Feb 12, 2008 | 11:10 PM
Blurry94's Avatar
Blurry94
I poured nearly 19 quarts of trans fluid in mine when I did a converter upgrade. At the time, I also added a B&M pan (holds about 3 quarts over a stock pan). So you're looking at 14-16 quarts if the pan, converter and trans cooler are all drained.
Old Feb 13, 2008 | 10:38 AM
Animalistic's Avatar
Animalistic
I can't say I have even seen an e4od but I have done many Dodge 727's and 904's without a problem going the bench press route. My biggest issue was that someone else had done it before and none of the bolts are the right size anymore. I end up bringing half my tool box under the truck with me.
I am too old for this stuff now. All of my upper body has moved to my beer gut
Old Feb 14, 2008 | 10:11 AM
icrman's Avatar
icrman
A bunch of 2x4's and lift and block under it.
Owners manual says 16.2 qts.
danlee
34
Mar 10, 2024 10:09 PM
joewaldner
Jul 22, 2010 10:05 PM
deisele75
Jul 18, 2005 07:51 AM
edderd
Apr 23, 2005 12:28 AM
