Front End Clunking
Front End Clunking
1999 F-150 5.4 192,000
Last weekend I drove into the mountains. Hit a lot of pot holes and used the 4x4 in some deep snow. Now there is a clunking sound coming from the front drivers side that I can feel in the floor boards when I drive over the smallest bump. Visual inspection didn't reveal anything and it still does it in 4 wheel drive. I know next to nothing about suspensions but I can turn a wrench.
Jacked it up. Moved the tire back , forth and up an down. No play in it. Caliper wasn't loose. Tire rod seems fine. Sway bar has all the rubber pieces on both sides of th top and bottom. Didn't look like there was a gap or any play in it. The shocks have at least 80,000 but they might actually be the originals. Need new shocks anyways so I think I'll start there.
properly.When the truck is jacked up,put another jack under the lower control arm and jack it up a bit then do your checks.
John7894
1999 to 2016 Super Duty
12-21-2011 04:14 PM
atikovi
1983 - 2012 Ranger & B-Series
04-04-2010 06:36 AM
