Leaf Spring Lubrication ?
Old Feb 10, 2008 | 06:08 PM
eman92082's Avatar
eman92082
I recently bought a new set of front Leaf Springs. I took them apart to remove 3 leafs, bevel and radius the leading edges, and the paint them. It occurs to me.... as long as I have them apart, is there any benefit to lubing them ? Dry Spray ? Graphite ? Grease ? Don't bother ?
I know there are vinyl buttons and inserts available. I'm not that worried about it but if it's just a case of applying something before I re-assemble, why not ?
Any experience with this ?
Old Feb 10, 2008 | 06:31 PM
cars2cool's Avatar
cars2cool
While I had my springs apart for my Model A pickup and '56 F100 I brushed on two coats of a graphite type paint. Went on wet and messy and dried to a rough texture, then burnished it with some 220 sandpaper. Put the spring stack back together and aerosol black spray paint the edges for looks. It will get rid of any squeaks and allow the springs to work as designed, actually better. I won't redo a vehicle now without doing this to the springs.
Old Feb 10, 2008 | 07:35 PM
53OlderThanMe's Avatar
53OlderThanMe
I know many of the vendors sell a plastic liner you can put between leafs to prevent squeeking.
Old Feb 11, 2008 | 11:50 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It has been many years since I did this and perhaps there is something better around now, but I used grease between the leaves and I think it helped...
Old Feb 11, 2008 | 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I tried some motorcycle chain lube, it is PJ1 brand. It has a light carrier that lets it penetrate, the carrier then flashes off, and leaves a lightweight, white grease that clings very well. I sprayed the springs I traded to BobbyT with it, and my new ones. and will do my rears after I clean them up.
The Eaton springs (which I believe you have, from JCW) could really use the radiusing, that's my only complaint about them. Real square cut.
Old Feb 11, 2008 | 01:05 PM
eman92082's Avatar
eman92082
Good Information - Thanks for the input.
E
Old Feb 11, 2008 | 01:40 PM
Brian_B's Avatar
Brian_B
I lightly painted my springs and put the poly liners from mid-fifty in them.
Old Feb 11, 2008 | 02:10 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
As Ross mentioned, he had sprayed pooky on the springs he donated. I didn't do a thing to them well, thats not true, I removed the bottom 2 leaves -- only to add them back in later) I just installed them.
I had a 1949 Pontiac. It had a light gauge sheetmetal wrapping on the rear springs that had grease zerk on it for lube.
How thick are the poly liners? that could add up to quite a bit of height once you get it between each leaf
Bobby
Old Feb 11, 2008 | 02:13 PM
Brian_B's Avatar
Brian_B
Bobby
1/8" thick maybe? I lowered mine (removed leaves) and put them back! LOL
I can't see any appreciable difference in height with them in between the leaves.
Old Feb 11, 2008 | 02:18 PM
bobbytnm's Avatar
bobbytnm
Hmmm...
My spring packs have 8 or 9 leaves, if that liner stuff is 1/8" think then its like adding almost an inch to the spring pack thickness.
Did you have to get a longer center bolt? longer "U" bolts for the axle? or am I just missing something here?
I could definatley see the benefit of dissassembling the sprink packs, cleaning all the old crud out from between the leaves and then reassembling the whole mess. I don't think I'd paint each leaf individually as the paint could potentially get all gommed up between the leaves.
Interesting stuff
Bobby
Old Feb 11, 2008 | 02:22 PM
Brian_B's Avatar
Brian_B
I do not have that many leaves. The 1/8" is a guess...it might be thinner. I think they settle down a little after driving a while too. Mine had long enough bolts in the spring packs to begin with. It really did not increase the height of them very much at all when bolted together. No changes at all on the U-bolts.
With the liners...the light paint should never gum up. It has not so far as I can tell. I think it has improved the ride. I know the springs were rusted together in places, so just cleaning them up may have helped.
When the weather improves...I have new shocks to go on.
Old Feb 11, 2008 | 02:25 PM
bobbytnm's Avatar
bobbytnm
Brian,
Cool. I almost wish I would have put some of the liner stuff in my springs but I'm not about to tear it all back apart now.
It was amazing how much gunk came out of my old spring packs
Bobby
Old Feb 11, 2008 | 02:34 PM
1Digger's Avatar
1Digger
I put the liners from Mid 50's in mine. It's more like 1/16" It looks like an I beam when you look from the end. The top & bottom of the beam might be 1/8, but the actual part that goes between the springs is very thin. Hope this helps
Old Feb 11, 2008 | 02:36 PM
Brian_B's Avatar
Brian_B
I don't know if I should admit this or not....
My driver side front spring pack is well lubricated!!!!! My steering box has a leak and it drips on the spring pack. Just one more thing I need to fix. LOL
Old Feb 11, 2008 | 02:39 PM
fergusonicford's Avatar
fergusonicford
Liner material w/ lips I had purchased years ago was only about 1/16" thick.... don't know if it helped the leaves slide or not.
