Headlight issues
Old Feb 10, 2008 | 02:10 PM
71FordCustom's Avatar
71FordCustom
Exclamation Headlight issues
i have a 71 ford custom ive been working on for a few years now, and have had a problem with my headlights since day one. They work great for about 15minutes then start flickering on and off, i turn them off for 5minutes then turn them back on they work fine for another amount of time. i have went threw numerous switches and just installed a heavy duty headlight harness gotten from lmc truck book. with all of this i still have found no luck. If any one knows the answer please HELP!!!!
Old Feb 10, 2008 | 03:21 PM
Freightrain's Avatar
Freightrain
Have you replaced the dimmer switch on the floor? These will fail and cause the same kind of reaction.
Welcome to FTE!
Old Feb 10, 2008 | 08:41 PM
71FordCustom
ya i have replaced that once awhile back i may def. try that one again thanks much!
Old Feb 10, 2008 | 09:09 PM
my72ford's Avatar
my72ford
yep,i would have to agree with freightrain..the dimmer switch on the floor will cause that problem. i had the same issue a few years ago. replaced it and worked fine
wizzard351's Avatar
wizzard351
the head light switch itself need to be changed it has a bilt in breaker that gets week. pull the lights on and reach behind the dash and feel the back of the switch itll get hot and cut out the lights
Old Feb 10, 2008 | 09:20 PM
71FordCustom
ya i have tried the switch thing bout 3 times and doesnt seem to work i guess it could be possible to have that bad of luck and get bad ones i dont know. and for hte floor dimmer ive replaced it once before maybe should try again. thanks for the help. just join on here today how do you get a pic next to ur name?
Old Feb 10, 2008 | 09:35 PM
Project_Roxanne72's Avatar
Project_Roxanne72
On the front of the truck check your ground on the headlight harness. Bad ground bad lights. Cant think of anything else besides the previous answers.
