Help Please!
Old Feb 10, 2008 | 10:02 AM
ashley6's Avatar
ashley6
Help Please!
Have an 06 explorer that wont start after normal cut off a few days ago, The instrument panel is not lighting up at all, when you turn the key acts like battery is dead but the battery is fine. could this be a blown fuse?
Old Feb 10, 2008 | 10:39 AM
blue beast's Avatar
blue beast
Check for corrosion at all connection points starting at the battery terminals
down to the starter and the ground contact to the motor. If you live where
they salt the roads the starter being on the bottom gets some salt on it and
rots the contacts. Pulling them off and sandpapering the connections so they
are shiny then using dielectric or vaseline when you reinstall them will prevent
it in the future!!
Old Feb 10, 2008 | 04:51 PM
Franklin2's Avatar
Franklin2
Turn the headlights on, and then try to start it. Write back in what the headlights do(if they go completely out, or stay fairly bright when you try to start it).
Old Feb 10, 2008 | 11:42 PM
Surge08's Avatar
Surge08
agreed. Have to find out if it is pulling any current or not
