well we are in the process of putting a 6" superlift suspension lift on my truck (front springs and rear blocks) truck is a 2001 F350 SRW 4x4. The problem that we are running into is that we got the front springs on and nothing else is connected. the axle is fully lowered and is not supported and it seems like the springs are forward 2-3 inches. Is this normal? Will the springs move back once the weight is put on. Also we disconnected the front driveshaft and the driveshaft will not connect now with the axle unsupported. will the front driveshaft bolt back up once the axle is loaded up with the truck on it?? thanks in advance!
