Bronco II Ford Bronco II
Rear Axle Question
Old Feb 9, 2008 | 01:52 PM
hotrodmerc's Avatar
hotrodmerc
Rear Axle Question
How much play should be in the rear axle side to side? I think my c-clips or the pin is wearing out. The rear axle is making some noise like a loose axle or c clip wear. It has 161,000 miles. I changed the fluid at 120,000 everything seemed fine then.
Old Feb 9, 2008 | 06:37 PM
rebocardo's Avatar
rebocardo
Double check fluid level. About an 1/8 of an inch in and out would be okay. Check for wobble at the axle shafts and slop at the pinion (remove driveshaft first).
Old Feb 9, 2008 | 07:44 PM
hotrodmerc's Avatar
hotrodmerc
Axle bearings and the pinion are ok. I guess i'll pull it down to check it out. At least it will get a fluid change.
Old Feb 23, 2008 | 08:10 AM
bobbywillis's Avatar
bobbywillis
put a jack stand under either side and grab your tire and try to move it if your play is right close to the hub then your bearings are wore out.
Old Feb 23, 2008 | 03:45 PM
tbolt 460's Avatar
tbolt 460
hes talking about the in and out play
Old Feb 23, 2008 | 04:31 PM
hotrodmerc's Avatar
hotrodmerc
I'm going to pull the cover to inspect the diff. and then check the axle bearings.
Old Feb 23, 2008 | 04:43 PM
tbolt 460's Avatar
tbolt 460
one way to take up the slack,add a extra shim to the side gears. i did that to my 8.8. i have no in and out play
